Chat Room Problems
Stephen Shepherd
I tried last night and was unable to get into the Chat Room. Tried again today with no luck, the software isn't allowing me to log in, so unless thing change I will not be hosting tonight.
Stephen
Chat Room Problems
Stephen Shepherd
Stephen
Re: Chat Room Problems
Terry in Almonte
Just tried it and it worked for me.
William Duffield
It failed here on the first attempt with a "Plug-in failure" message, but I refreshed the page and it worked on the second attempt, but only after I ok'd a security warning for ParaChat.
I'm using MacOS 10.6.8 and Safari 5.1.10, and I'm using ClickToFlash to enable the Flash plug-in manually.
BrianMonumentCO
I just tried and got in.
It must be a personal problem..... Er maybe a PC problem.
I am running Linux with Mozilla Firefox 22.0
Re: Chat Room Problems-works for me
Bob Entwisle in NJ
Worked fine last night, though I recall firefox wanted an update to the java plugin or something, which i skipped.
I just tried it now and got in no problem.
Hope to see you later.
Bob in NJ
Stuart Hough
I had problems last week. Fix was to delete and re-download Java from their website. No problems since then.
Java Updates
The updating process is outside of WoodCentral control. Our chat room runs on a Java applet, and Java is continually updating their software for security reasons. If you can't get into the chat room, there should be some kind of error message that says your version of Java is out of date, and all you need to do is follow the bread crumbs and install the update. I just had to do this myself. Usually, though your browser will continue to run our chatroom on the previous version of Java, but you might have to click a button that says Run This Time or something to that effect.
It takes only a few minutes to update, and the added security is worth it.
Let me know if you have any further trouble and I'll see if I can walk you through the process.
Guillaume Dery
Just tried it and I had to OK Parachat to run but then was fine
