New WoodChat!
Sliding Dovetails with the Veritas Small Plow
Re: Sliding Dovetails with the Veritas Small Plow
Edward in Vancouver
Thanks for the tutorial. I might attempt to try sliding dovetails in a few years.
Right now I'm still getting comfortable with the LV plough. As many others have noted, it is an excellent plane but has one flaw--the depth shoe. I liken the plane to a girlfriend who is fun to be with and easy on the eyes, but you can't trust her 100% when your back is turned.. I have been "experimenting" with my own depth shoes, have tried brass toilet flange bolts, and all sorts of brass shims (.22 shell casings slit open...) in the clamp, but still no success.
A simple fix
Hi Edward
This is something that bothered me as well, but I do have a fix that makes the depth stop reliable.
The problem is that LV make the tools too well! As a result, the shaft is smooth steel and does not offer enough grip/resistance against sliding. One should not put pressure on a depth stop but even a little has proved too much here.
The first thing to do is roughen the steel shaft with sandpaper (enough to give it a matt finish).
The second item is to create a slot in the knob for a screwdriver. It is possible to use fingers to tighten the knurled knob sufficiently, however it is then hell to undo later. Use a screwdriver to tighten and loosen.
I used a Dremel ...
Note that this could be a factor on all of the adjustment knobs. I have communicated this to the LV team. My solution is to add a screw slot to all the knobs and remove the shine from the rods.
Re: A simple fix
Edward in Vancouver
Thanks. I'll do the "mod" this weekend.
