Sanded vs. unsanded grout--OT
Wiley Horne--So. Calif.
Knowledgeable ones,
For grouting floor tile, as in a bathroom, do you use sanded or unsanded? For that matter, what is the point of one versus the other?
Thanks in advance!
Wiley
Knowledgeable ones,
Thanks in advance!
Wiley
Re: Sanded vs. unsanded grout--OT
david weaver
Sanded grout will fill/span a wider gap nicely, but won't fill well in narrow gaps (doesn't flow in).
What I'd use would depend on the gap sizes you're looking at. Most grouts will describe somewhere on the package what groove sizes/widths they're suggested for.
Thanks, David, that's very helpful! These will be narrow gaps, with the tile on mesh, so will use unsanded grout. Thanks again,
Wiley
Guillaume Dery
Unsanded for tiles in shower walls and any small gaps
Sanded for pretty much all floor tiling unless you really space your tiles close together. (1/16th of an inch is the recommended transition point but you can push that up to 1/8th without ill effect usually)
Unsanded is more fragile and will not hold up well for floors in my experience.
Whichever you end up picking, be sure to seal it before you get back to regular bathroom use. Trying to bleach out staining in grout is not fun whatsoever.
GD
TomD
Just one question on the sealing, some of the stuff I have used is epoxy based, and I did not seal it, and it seemed to last really well with colour. There are these old school types, and the more modern ones, any difference on the sealing instructions.
Guillaume Dery
Epoxy Grout, while a right royal PITA To work with, does not need to be sealed and won't absorb stains (generally speaking). Cement-based grout (sanded or not) should always be sealed and the sealant refreshed every year or 2.
It basically comes down to porosity and absorption. Real epoxy grouts have the other benefit of high durability.
Not a pro by any stretch of the imagination but I have done 3 complete house renos and have helped a tiling contractor friend with many jobs
GD
david weaver
Follow up to what Guillaume said - I used mesh joined 2x2 porcelain tiles and used sanded and it worked well. The gaps are 1/8" (which is the bottom end of the sanded grout range on most packages I've seen). I don't know as much as guillaume does (due to less experience) but I tend to use sanded where I can, especially because there will probably be places around corners or something where gaps are a little larger and unsanded does a very poor job if the gap gets wider than about an eighth anywhere.
If I had tiny tiles with 1/16th gap, I'd probably not use sanded, but I haven't had to make the decision.
I'd probably follow the instructions on the bag of whatever I bought, but like some of us, am less picky about what I do with home improvements than I am about making tools or making furniture.
Thanks for the followup David. The grout i want to use is sanded, as it turns out, and instructions say it will work down to 1/16" gap. My gaps will be no less than 1/16", so sanded it is.
Thanks to both you and Guillaume for the specific and detailed advice!
Wiley
TomD
Thanks GD. I remember a terrible mess when my dad grouted our kitchen. There was brown mud everywhere. So it was with trepidation that I approached my little tile jobs. Those foam trowels made the whole job easy.
