PEC Double Square Review
William Duffield
Late last summer, we had a discussion here on machinist's squares, with some recommendations on the squares made by PEC.
Last week, Alan Turner, of the Philadelphia Furniture Workshop, gave a very useful presentation on measuring and marking at the meeting of the CJWA.�
As most of the CJWA members know, I carry a 4" double square in my shirt pocket everywhere I go,� as I find it to be about the most used and versatile tool for woodworking that I own. I used to carry Starrett brand squares, but as you are probably are aware, they are very expensive. After� having dropped more than one into my garden, I am now very careful to choose shirts with secure pockets.�
I was asked to recommend a for high quality, inexpensive source for a viable alternative to the Starrett double squares, and thus wrote this review and distributed it to the CJWA membership.
I get mine from Harry J. Epstein Co. www.harryepstein.com. These squares are made in the USA by Products Engineering Company (PEC). I believe PEC manufactures the "Made in USA"� squares offered by Lee Valley and Woodcraft.�
For a wide variety of PEC squares: http://store.harryepstein.com/c/ProductsEngineering.html
The hardened blades have a satin finish and 4R graduations (8ths, 16ths, 32nds and 64ths of an inch). The heads however, are not hardened.�
Some advantages and disadvantages of the PEC vs. the Starrett squares:
The PECs are substantially more economical that the equivalent Starrett squares. Harry Epstein currently sells the 4" double squares for $15 and the 6" double squares for $17.50.� Compare to the Amazon prices of $62.75 and $78, respectively, for the Starrett equivalents. I can detect no difference in their accuracy, with the exception of one I bought from Lee Valley� several years ago. Lee Valley, of course, took it back and refunded my money without question.�
These rules are "Blems". That means they have one or more cosmetic defects. These defects do not affect the functionality of the squares. They are not marked with the manufacturer's� logo.�
Once the PEC blade is removed from the head, the screw clamp assembly can easily fall out and roll off your bench. The Starrett screw clamp assemblies must be disassembled to remove� them from the heads.�
The hook on the end of the PEC screw clamp does not slide as easily into the groove in the blade, making blade reversal a bit more tedious. This can easily be remedied with judicious� application of 600 grit sandpaper to soften the edges of the clamp. (Or, you can buy two, at less than half the price of a Starrett, so you don't ever need to reverse the blade. :^)
The heads and blades of the PEC 6" and 4" squares are interchangeable; the Starretts are not.�
The Starrett 6" double square head has a level, while the PEC 6" head does not. I've never seen a hardened Starrett 4" double square head, and I don't think they make one.�
Note that, as Alan pointed out, if you do buy a Starrett, make sure you get one with a satin finish blade. I find that the less expensive, polished finish Starrett blades are very difficult to read,� and in some lighting conditions almost impossible.
While a 6" double square is not conveniently carried in a shirt pocket, I find it to also be very useful in the shop.�
The heads of the PEC squares are exactly 1" wide; the Starretts are not. This is convenient when doing inside measurements, as you can set the end of the blade flush with the edge of the� head (by feel) and use the rules on the blade directly for inside measurements.
. Fortunately, the side that's corroded and hard to read is the side that reads from 34 to 48 inches; the 1-14" side is pretty clean.
Maybe, someone at the factory cut off the "0" and the eighth inch or so of steel that was needed to etch the numeral?
