Re: Trying plane
I have a beech trying plane that I have used on almost every board for 35 years. It is 22 inches long, the mouth is 7 inches from the front and the angle of the tote is somewhere around 65 degrees. I think it is a good design. I would say that you want a fluid wrist rather than a rigid wrist; the wrist angle changes as the stroke progresses. I think that for the least stress on the joints they all should be fluid, not trying to hold something rigid throughout the stroke.
The new design looks awkward to me. If someone had a large body of work with a traditional design then tried something new for a few years and liked it, it would be worth noting. However using an altered design for a very short period of time does not give much information.
Hi Warren
Reading your post set off a light bulb. I compiled a set of measurements about several planes, and these are meaningful to me. Hopefully also to others. While I do not mean to suggest that they should create rules for the design of a plane handle - since I do agree with you that the wrist changes as it pushes a plane ... and that it changes (or needs to change) position and angle as the conditions change - there is a pattern that is recognisable.
I'll start with a comment about the new handle for the Trying Plane. It may look awkward, but it works. The question is "why does it work when the previous handle - so close in angle to the one you like (above) - did not work at all?".
One answer to this is simply that the handle angles work for the respective plane designs. Your plane has a handle of around 65 degrees (which is the same as Stanley), while the Trying Plane handle is similar to a Veritas at about 75 degrees. Your trying plane's toe/mouth is 32% of the length of the plane.
Here are measurements of other planes I have:
The first statistic of relevance is that, with the exception of the Trying Plane and Jointer, all planes have a mouth/toe percentage around the 35% mark, which is similar to yours.
The exceptions here are the HNTG Trying Plane and the Jointer, are similar in having a significantly higher percentage (the mouth is relatively further back), with the Trying Plane even further back than the Jointer.
Inference: the longer the toe/mouth percentage, the more the plane will benefit from a horizontal vector, and the shorter the toe/mouth percentage, the more the plane will benefit for down force when planing.
The second statistic is the height where the handle is held relative to the length of the body. The lower planes (Jack, Jointer, Trying Plane) all have a low centre of gravity. They appear to work more efficiently with a low centre of effort (forward vector). The relatively higher planes require more down force. Note that the Krenov smoother (made by JK) has a 45 degree bed, while the lower coffin (shopmade) has a 55 degree bed. It requires significantly more downforce to push than the Krenov. A higher body (3" is common) would be expected to require even more downforce.
My thought at this stage is that Stanley make a handle that has the best of both worlds. It can be held at the upper end, where it imparts downforce. It may also be pushed by the heel of the hand when the vector is horizontal. Some planes, however, may benefit from one extreme or the other (in some cases substitute the hand for a handle). That is for discussion.
