Re: a few spokeshave questions
I would like to pick up a spokeshave(s) to help shape spoon and ladle handles, most of which will be curved. It will be used to hog off some wood as well as make fine detailed cuts. I am looking at dave’s shave (flat) and the veritas wood handled flat spokeshave. Will dave’s shave hog of wood? Also the veritas can be bought in a set (with good cost savings) does anyone have experience with the concave and convex shaves, and are they useful in what I intent to use them for?
I love the idea of antique but I really don't have a lot of shop time to figure out how to renovate and make it work. Thanks in advance from a guy who has no experience in spokeshaves…
Hi Matt
As others have recommended, drawknife to rough out and spokeshaves to shape. Spokeshaves, rasps and scrapers to finish.
Whether vintage or new, there are differences, and the choice of spokeshave can very personal. For example, I prefer spokeshave without adjusters just because this makes them that little bit less top heavy. I am used to adjusting woodies with a hammer, so this suits me just fine. Nevertheless, there are excellent spokeshaves from LV that use adjusters.
I mostly turn to the 3 Boggs shaves from LN (flat, round and curved), along with the LV LA spokeshave, which excels on end grain (and would be a metal equivalent of one of Dave's shaves). A recent purchase of the LV version of a small Preston round has proved really useful for tight curves (note that this one did need some tuning, but came up very well). I imagine that anything from LV, LN Dave, Woodjoy, and Clifton should work out of the box, or require only minor tuning.
In the vintage area I really like the Stanley #53, which has an adjustable mouth and is excellent for thicker shavings. The Stanley shaves all generally have wide mouths and take a thicker chip. This is important when roughing out.
The flat shaves do a reasonable job on gentle curves as well, and it is only when the curve gets tighter that a round bottom is needed. These come in different sizes, which have varying degrees of curve, and less or more reference surface at the mouth. It is this that makes them tricky to use, since you are balancing on a small area. They require a slightly different technique to use than flat soled shaves.
The flat shaves also come, like planes, with different bed (and cutting) angles. The LN bed is 40 degrees. I have HNT Gordon at 55 degrees. For dry wood with interlocked grain these make a difference. Unlikely to be an issue for green wood when carving spoon handles.
Do not forget that you can make scrapers to suit the shaves you want. These are very useful for specific shapes. I've filed them out of old bandsaw blade. This one was made quickly and simply ...
