Re: Paul, a question
Paul in NJ
Hi Patrick,
I have some small rectangular slip stones that I hone with. First I clamp the blade by both tangs in my metal vise. I place the stone perpendicular across the blade and rub it back and forth. I say perpendicular because it helps keep me from rocking the stone and dubbing the edge. Next I turn the blade over and clamp one tang in the side of the vise to give me access to the bevel. I hone the same way, the stone perpendicular to the blade. I have hollow ground the bevel on my grinder freehand but it takes a steady hand and is easy to mess up. I imagine you might fasten the blade to a stick (maybe as simple as using baling wire) and be able to use the rest on your grinder. Like I said before, I try to buy shaves in good shape. I think Mike Dunbar in his book on restoring tools might have some sharpening info.
I don't know of any jigs to do this.
Paul Dzioba
