Re: Looking good, Derek
What would concern me more, though, would be any imperfections in the right angles that you so carefully crafted between the faces and the cheeks of those fingers. You'd be using the back of your crest rail to mark out the fronts of your arms. I wonder how perfect that is likely to be, regardless of how well you've measured those right angles. Whenever I needed something to fit within another piece perfectly, I made a test piece from metal or hardboard depending on the tolerances I was after, and used it to gauge the negative shape -- in this case, the back rest fingers. The gauge piece will tell you where and by how much the fingers vary from perfect compliance with the shape of the gauge, so you can further tune up the fingers, and then use the gauge itself to do the layout. On thick work like this, though, you'd still have to verify the perpendicularity of the cheeks; the gauge would only tell you if the shape was uniform.
Hi Ellis
A short while after I had flattened the face at the end of the arm (where the fingers would be sawn) I realised that I had focussed the wrong side. Planing that side meant that I could not match the face as I should have planned to do. It was then too late to plane the other side as the wood remaining would then be too narrow for the dimensions. As a result I had to ensure that the rear side of the backrest (where the finger joint would be sawn) had to be perfectly parallel to transfer the markings. The die was cast and I had no choice but to continue down this path.
Reflecting on this I now realise that it probably makes no difference whether the markings are transferred from the face or the back: they have to be perfectly square otherwise gaps will show once the carving is done. The real joint lies in the centre, not at the outside. It has to be straight and square all the way through.
I think the idea of a test piece is helpful. A tight fit on one side must be a tight fit at the other side when the piece is flipped over.
The blue tape method aids accuracy a great deal as it is so easy to see lines. For this the tape needs to be cut with a blade, not an awl. I shall redo the marking with fresh tape as I have had an idea what to use for a knife. A long, one-sides blade is needed, and ideally two blades to cut from opposing directions. It has occurred to me to try the blades on the Veritas skew block planes. We'll see if this works. Once the marking is done, the blue tape should offer up an exact copy of the waste. It is left on the workpiece and one saws against the edge of the tape.
Thanks for giving me the push to do the fingers with rounds (and not points). It has been an interesting puzzle .... and that is where all the fun lies!
