Question for the plane experts
Edward in Vancouver
Picked up a rabbet pane at the flea the other weekend, still trying to figure it out.
It's 3/4" wide and home made. The maker made the stock in two pieces, the first was and "L" shape, then he excavated for the iron, the he glued on teh second part, and then he bolted on a steel sole. The iron is home made from an old file.
The toe, which is also steel-clad, is a good 1/8" higher than the rest of the sole, when I show the bottom of the plane to a known flat surface, the toe is a good 1/8' higher than the rest of the sole.
The plane can be described as "work-a-day", not butt-ugly, but the owner did not bother with and fancy work. It is obvious that the owner had spent some time fitting the steel sole to the stock, shaped the wedge,and took some time to grind and shape the iron from an old file.
Can't figure out why the toe is higher than the rest of the sole, and I can't make a decent rabbet with it either...
Any suggestions?
