New WoodChat!
The Chair – The arm-backrest joint (part 2)
Re: The Chair – The arm-backrest joint (part 2)
There is one non-powered approach to drilling precisely aligned holes in the ends of the joints: a post drill. I think you mentioned you made another rule - no new tools for this project. There is a clear line between a purchased old tool and a new jig you have built for the project, but the line between a new shop made jig and a new shop made hand tool gets a little less distinct.
Tom in Toronto
I'm still pulling for float. Or a small plane.
Put it in the drill press and turn it by hand. You are in distinction without a difference land pretty much if you use a "hand drill" Not a gimlet, and a doweling jig.
Derek, the doweling jig idea could be made to work, but I think that if you're going to create a new jig, you might want to make one that has guide bushings for two or three holes and a firm reference off the end face and one side face of your arm and seat blanks. That way, the holes will be a fixed distance from each other. Jigs like this always cam in handy when drilling dual holes for drawer pulls, etc.
Tom in Toronto
If you take apart a C clamp (I always seem to have one in that state from backing out the screw and popping the swivel jaw), then mount the bushing in the threaded area. Then you drill into the fixed jaw, and mount a point in that. So you now have a jig that aligns the drill bit square to the surface, and aligned with the exit point.
Give some thought to ...
.... the complimentary finger that has to receive the rounded end. The difficulty is not just the drilling of the hole (to create the one round), but the rounding of the finger (to fit).
I'd do that with files
Maybe my rustic side is coming out here, but I would just file away the point until the fit was right.
Re: I'd do that with files - or
Tom in Toronto
You might have to spot the whole thing in to actually get a melted fit. I would be somewhat ok with relieving the center of the joint that does not show, but I am not so sure how one knows where the middle is.depending on how the pattern works out. The challenge with the bullets is getting them all to bottom at the same time, because they sure aren't going to compress.
If you are drilling the holes, that is your male mold, so you need a female mold to go with it. So get a piece of wood, of the right size and shape. Use an oversized rasp to cut a channel, or you can use any other thing you have that make a groove. Now wrap some sand paper, of high quality, water proof, with a good aggressive long lasting tooth to it, around the drill with the grit on the inside. 1x42 belt might be a good source of "paper". Better yet, use a pin or rod of the exact same diameter as the drill bit. Or use the shank of an extention bit, or other long bit like a spade. Use clips to hold the paper tight around the pin/drill/rod. Then mix up some thickened epoxy and glue the paper into the groove, and let that set until hard. Remove clips and pin/drill/rod, and trim paper. You now have a specialty cutting tool that is the exact size of your bit, and that is a female mold. You are welcome. :)
Tom in Toronto
I hope that is clear, I explained it to my wife who isn't following this, and it wasn't clear to her. In the description I go back and forth recommending sandpaper and rod material, in a kind of confusing way. Let me know if you need pictures, or something.
My biggest concern
Andrew F in Australia
One again, this is in tiny font while I'm watching England cop another walloping. Trust that I've caught all autocorrect errors with apologies if I miss any.
Just as a data point only, I'd come at it differently.
I'd make up a template out of a bit of sheet metal to get the finger layout accurate. You'll need two, actually, one for the male and female joint.
The biggest problem that I can see is cutting the finger joint faces accurately, making hole location a secondary consideration. I'd use the templates on both sides of each joint and pare/file them down carefully.
As to the hole, I'd drill halfway through from each face and align them carefully. You can always pare the joinery to fit. I wouldn't overly worry about the joint yet. As Ellis (?) said, make your drilling template out of a bit of 10mm steel plate or similar. This'll accurately align the holes but you've got to absolutely get the jig aligned to precision. To quote the Lion King, "frought, I tell ya"
The approach is take would be to lay out joinery using templates, and then set the location of each hole centre using dividers on each face,and etc ie: machinist layout techniques before I cut any joinery. All that's visible is the outside face so I'd drill through from either side. Drill holes then cut the fingers. That way, a tiny deviation from plumb won't affect the look too much and can probably be cleaned up with a chisel.
As i said, just an observation as a data point. It's a difficult thing to try and replicate by hand as this joint is really engineered for the high accuracy of shaper tooling.
In the time is taken to write this we've scored 50 runs, so must away.
Good luck with it over the weekend.
AF
Re: My biggest concern
Hi Andrew
Excellent ideas. I have a few others, and plan to try them out on some scrap over the weekend.
Hopefully others will post theirs as well.
14 runs to get off 38 balls.
By the time you read this it will long be over.
