Marking Walnut, Wenge, Cocobolo, etc.
William Duffield
I attended the annual conference on Woodworking in the 18th Century last week in Williamsburg. While there, I learned an old trick for marking dark, resinous woods, such as black walnut, wenge, cocobolo, etc. This is from David Salisbury, Colonial Williamsburg joiner and cabinetmaker. David is the guy on the cover of this book: http://www.amazon.com/Tools-Working-Eighteenth-Century-Decorative-Publications/dp/0879350989/ref=sr_1_3?s=books&ie=UTF8&qid=1390838416&sr=1-3&keywords=18th+century+woodworking+tools
While I haven't had much problem with walnut using a Pilot P500 gel pen, the darker, "oilier" woods are a problem. I've tried using a drafting lead holder with yellow lead, but the points are too fragile and too difficult to keep sharp.
What works is a soapstone pencil. These are available at welding supply stores, as they also are used for marking steel. Here is a "boutique" source, online, with photos.
http://www.brooklynslate.com/products/soapstone-pencil
These are rectangular, with flat, square and parallel sides, typically 3/16" thick by 3/4" wide and a few inches long. They are sharpened with abrasives (a grinding wheel or sandpaper, for example), in the shape of a single edge, single bevel marking knife.
David was using one for marking double through tenons on the ends of some walnut rails. He had made some setup blocks, which he stacked next to the rails, and laid the soapstone flat on top of the blocks to transfer their thickness to the walnut. The soapstone left fine, highly visible lines.
