We value your privacy.
I came across an old combination hand plane hidden away in my shop with the tote missing. (There's still a little piece of the bolt that obviously broke off years ago left screwed into the metal part.) Is there a more or less accepted way of going about making a new one? As I think about it a little, finding the right bolt and getting the angle right worries me the most.
Depending on the manufacturer of your plane,there are many sources for old plane parts around the web. As to getting your tote bolt angle right,I like to drill and countersink(if it needs it) first on a square piece of wood. Then I get the angle from the plane using a bevel and then shape the tote around the drilled hole.I hope this makes sense.---Jack
Eliot, check out Hardware City Tools. Sometime during 2013 Bill Rittner's blog shows how he makes totes. He's very helpful to anyone who corresponds with him so he can get you off to a good start. I bought a tote and knob from him to replace those on a LV plane.
I have an old #5 with a broken tote. The grain of the wood runs horizontally and the break is where you would expect, right in the middle where the tote is thinnest and the break is along the grain. Admittedly I have not done much research, but wouldn't it be better to have the grain run vertically? Jerry
Horizontal grain is necessary to the front part that holds the front bolt. Supposedly the long bolt holds the handle part together.What usually happens is with humidity changes,this bolt loosens up and then the handle breaks more easily across the grain.So,always check your bolts.---Jack
