Whoops....
Jack Guzman from Maine
I've been following the plans pretty closely while building this high chair. I wasn't really happy with the layout for the arm. It called for gluing up three pieces into the arm curve shown. The problem is that because of the curve I was stuck with grain runout. I figured that this was the way the original was built so it must have worked and I will go along with it.
This morning I finished shaping the spindles and started to dry fit everything to see how well it would go together. I got all the spindles started and was gently tapping the arm down going back and forth along it. I got the short spindles started and tried to bring the arm to the arm post by flexing the spindles.Just as I got the tip of the post into the arm it snapped as you can see.
I am going to build a new arm. This time I will use green oak and steam bend it to get the grain in the desired curve before shaping the arm.
Now I wonder if the original actually was cut from unbent stock as the plan showed or if it was wrongly drawn that way by the plan creator.
Nevertheless from this point on I'm using common sense. ---Jack
