New WoodChat!
The Chair - Tenons
The Chair - Tenons
The Chair - Tenons
Here is the link to the sawing of the tenons. Not straight forward (is anything?).
http://www.inthewoodshop.com/Furniture/TheChairTenons.html
There is also a partial answer to how I plan to cope the tenon shoulders.
Question time again :) How would you go about making the mortices with hand tools?
Re: The Chair - Tenons
Robin Corell in Atascadero,CA
most of my work has a strong curvilinear emphasis. I always do my joinery before cutting the curves. This included mortices in legs before turning.
On the one occasion I had to cut a joint on a piece that was already shaped (compound curve) I spent a fair bit of time making a jig to hold the piece so the joint I was cutting was parallel to my bench, then just chopped square to my bench.
In your situation it would be a fixture to hold the leg so you are chopping straight down. For the angle between the two I would cut one mortice and fit a scrap in it then rotate the leg in your holding fixture until a digital angle finder sitting on that scrap placed in the first mortice reads the correct angle.
Robin
Hi Robin
I would have preferred to do the joinery before turning. However I have been overcautious because I was not sure how to deal with the angles. Point-and-shoot was more predictable, albeit it with more handwork.
I do have a strategy to help keep it all square, and will post pics of these next time. That may be a few days away as so far the morticing is excruciatingly slow (as I am being excruciatingly careful!).
Tom
I would have done the mortices in the square, or at least that is what sounds best under the circumstances. If I was doing what you are doing I would do the John Alexander thing, which is specifically a method of using a brace with great accuracy to drill holes at compound angles.
For those that haven't the tape, the leg is set in pulpits in a horizontal position rolled towards one by the appropriate angle. The brace has a level built in so it is perfectly horizontal. Any secondary angling is done with bevel, sighted, this would be cocking to the right or left.
The rotational angle of the leg could be set as a tweak on Alexander by mounting square blocks, these are fastened over the round, and parallel to each other and allow setting forward and aft angles with an digital inclinometer (some smart phones have these), or other means, the old protractor and plumb bob method being a traditional favorite.
(Tube blocks are a fun to have thing. Spend less on knurled brass and more on the stuff that really makes a difference. Well... Arguably)
http://www.paragonmachineworks.com/cgi-bin/commerce.cgi?search=action&category=TB07
Of course one can just glue something on...
The leg could have been cut in square, or in round, but a third possibility is cutting the leg to a cylinder, this could make certain aspects easier. The final tapering could have been done lather. A fourth option could have been to taper the leg, all but two reference points.
Another thing I might do is to leave the cope to be finalized as the parts come together. Yeah, maybe a bit of a bail, but it isn't so bad to make one off projects in a way that they can't fail to come together.
What glue will you be using?
The Chair - Morticing
Here is the next instalment - the start of the morticing. This shows one side of the chair, that is, two mortices completed. There is just so much to do in this regard that I thought it best to break it down into smaller chunks.
Your thoughts?
Link: http://www.inthewoodshop.com/Furniture/TheChairMortices.html
Re: The Chair - Morticing
Larry Barrett
Derek, it looks like you have taken the length of the lead screw on the auger into account. Good thing; you don't want it poking through on the other side. Using a Forstner bit or the Stern bit Alexander recommends would allow you to have a deeper mortise, or at least have less to worry about with the lead screw.
Tom
NIce.
