New WoodChat!
Mortises: Paring Before Chopping
Phil
I was wondering how common it was to make a light paring cut between the
mortise marking gauge lines prior to the initial chopping cuts, to help register the blade more accurately. Is this practice likely to enhance the overall mortise quality or does it introduce an additional chance for error?
Re: Mortises: Paring Before Chopping
Phil
Derek: Thanks for chiming in: with a multi-media response. I had just honed a new Ray Iles chisel and decided to see how it worked at paring: it does take a keen edge. Not sure how much of a parer it will be after its been through a few mortises. Other than your write-up, I've not seen the paring approach discussed. Seems like it has the advantage of requiring hitting only one target, i.e., staying inside the lines for the paring cut, vs. hitting multiple targets when registering the chisel each time for a chopping cut. And here I thought I was blazing new trails.
Hi Phil
I learned this method from others. One name does spring to mind and that is Adam Cherubini, but singling him out may be a unfair to others. I believe that Moxon wrote about this.
Warren in Lancaster, PA
I think that if you have good technique, it is much faster and cleaner just to chop.
Patrick Gibbons
I think Warren and Derek are both right. However, I always pare first before chopping. I like Derek's strategy because it looks like it would cut down on bruising the ends of the mortise. Usually that doesn't matter because the tenon is not full width and the ends of the mortise are covered. Recently I made a tenon full width and the bruising marred the looks of an otherwise nice looking project. I didn't even anticipate it until it was too late.
David Charlesworth
It's a technique shown in Robert Wearing's, The Essential Woodworker volume.
Happy New Year,
David
Phil
Well, with David Charlesworth (and Robert Wearing) endorsing this technique, I need no further convincing: paring, then chopping it is.
Thanks David for the guidance, and Happy New Year to you as well.
William Duffield
Adam's technique is interesting in that he doesn't use a mallet at all. It is paring, from start to finish, with pressure from the shoulder pushing the blade into the wood. The shoulder is padded by a hand wrapped around the end of the chisel.
If you chop, after you've worked from one end to the other, you just turn the chisel around to work back in the other direction. If you pare only, then you will probably find it easier to turn the stock around each time you work back to the other end, unless you are ambidextrous. An advantage is that you can do it in an apartment or after the kids are asleep at night.
