Lee Valley Chipbreaker
There has been much re-newed interest in the use of the chipbreaker in tuning a plane. We no longer hold the belief that the chipbreaker is simply to support or stiffen the blade. Indeed, the very first review I wrote was on the, then, newly released LN chipbreaker. That must have been about 10 years ago. Today the chipbreaker is seen to be an important factor when tuning a smoother.
Very recently I ordered a couple of Lee Valley chipbreakers. One was for a Stanley #3 I had restored, and the other was for a #4 1/2. There were also PM-V11 blades to go with them.
Today I had the thought to take some photos and thereby share with others my observations about this purchase. For contrast I shall use #3 chipbreaker/blade combinations from Lee Valley, Lie-Nielsen, and Stanley.
LV, LN, Stanley
At first glance the LV and LN chipbreakers are similar in shape and design. The LV is shorter than the LN.
The LV sits firmly on the blade, is a perfect match ...
... as is the LN combination ...
Both have just enough flex to pull down firmly onto the blade.
The Stanley ...
... needed a little extra bend in the body to create a tight bond. The thin steel is very flexible, too much so. What happens is that when it is set close to the edge of the blade, and then tightened, the chipbreaker will "stretch" over the position desired (if not careful, over the edge of the blade).
The similar designs of the LV and LN are also evident on the reverse side ..
There is a little more support at the front of the LV. This is not significant once in use as the front of the chipbreaker rests on the leading edge and not the flat. However the wide support of the LV did make it easier to balance on the medium when lapped flat (which does need to be done ever now-and-then).
Now the important side I want to show is the other side - the chipbreaker screw ...
What you will notice is that the LV screw is knurled and the LN is flat. The LV screw is also significantly thicker (The Stanley screw is also knurled, but it is the same thickness as the LN).
Why is this so relevant?
Because the LV screw can be tightened with finger tips and both the others cannot. Finger tightening enables the chipbreaker to be set much more easily at the edge of the blade - set it, finger tighten it, and use a screwdriver to finish when happy.
Here is the LV being adjusted ..
The other item that may simply pass by unnoticed is the hole for the frog screw. The LV is long, and this enables one to use a screwdriver blade as a hammer to adjust it rearwards.
The LN has a small round hole - very neat, but it makes it difficult to adjust in the same way.
The shorter LV and Stanley chipbreakers expose more or the blade slot, and the screwdriver blade again can be used as a hammer to tap the chipbreaker forward. The longer LN chipbreaker leaves open none of the blade slot open, and cannot be used to adjust in the same way (refer to the initial photo for illustration).
It is relevant to note that the front edge of the LV and LN chipbreakers both angle at 25 degrees. This is too low for Bailey-type planes with a 45 degree bed. A secondary microbevel of about 75 degrees needs to be honed. This is easily and quickly done freehand. More on this in further article.
In summary, the Lee Valley chipbreaker is excellent and, in my opinion, the better design of the three.
