New WoodChat!
Veritas - Innovation in Tools
Making small knurled-head screws (long) *LINK*
I was asked to post in a thread titled "Missing Screw" about my method for making small knurled-head machine screws for applications like the cap iron screw for a spokeshave. I considered titling this "Knurled Knob Knotes," but decided on a title that I hope will be a little clearer.
Some years back, like Jack Guzman, I scored an otherwise very nice spokeshave missing the tightening screw on the lever cap. I had, at the time, just noticed some lamp parts in the hardware store that seemed to have potential other uses in the shop; from this coincidence came my fairly simple method. One of the things I like about this is that it doesn't require a metal lathe or any complicated tools. I'll first describe my method, then point out some other, related information that could expand on my method in some useful ways.
First, the parts:
A lot of lamps are kind of stack-laminated, with various parts being stacked up to make an assembled lamp. Caps are used to provide an attractive termination for the pipe on which the parts are stacked, or to close off threaded holes in such things as ceiling fans that offer accessory lamp kits (when you don't use the lamp kit).
Reducers screw into these caps to transition to other thread patterns.
What I did was pick up the basic knurled caps my hardware store had, with some matching reducers. The caps were 1/8" national pipe thread, a fairly common size used in lamps (the long conduit running up through a common wooden table lamp is usually that size/pitch). The reducers, if i recall correctly, stepped down to No. 6-32 machine thread. They can be tapped out to larger sizes, up to No. 10 machine screws (or see "Things I learned..." below for simpler approaches yet).
Tapping is simple: I picked up a 1/8" hex pipe cap in the plumbing aisle to hold the reducer while I tapped it. Looking back, I'd have been better off with a hex pipe coupling, but maybe they didn't have those in stock. Hex matters over the round pipe cap/coupling because it's easier to hold firmly in the vise. My taps have yet to bottom out when the reducer is screwed into the pipe cap, but, if they ever do, I can just drill out the end of the pipe cap to make a clearance hole. The brass is soft enough to tap dry, and I don't even drill it out if I'm stepping up just one size. Once I finished tapping out the hole to the desired size, I gently unscrew the reducer from the pipe cap with pliers.
I then need a length of threaded rod. The best way to make one of these is to take a machine screw of the right size, pitch, and length, and screw it into a pair of those electrician's pliers that strips wire and cuts screws shorter, from the back side (the cutoff that comes out the back side of those pliers is usually pretty torn up, so the part you want to keep should come out the front side). I use the two-nuts method of working with this length of rod: thread on two nuts, then tighten them together. With this, you can remove the threaded rod from the pliers, install it in the reducer, etc., by using a wrench on the nut away from the direction you're moving; that is, the nut you're turning should apply pressure to the other nut.
Now you're ready to put it together: take some sleeve or bearing retainer (I've always used Loctite because that's what I learned on, but there are other brands). Sleeve/bearing retainer is similar to threadlock, but yields a much higher final strength. Put a drop on the reducer and thread it into the cap. Put another drop on the internal threads, and install your length of threaded rod. Once it bottoms, remove the two nuts you've been using to manipulate the threaded rod, wipe off any excess sleeve retainer fluid, and set it out of the way on the bench for 24 hours. Sleeve retainer is used to hold bearings in automotive and machine applications, where the bearing is a little loose in its housing; I've used it to hold an axle bearing in place on a 2800-pound Volvo wagon. Once it sets, it does NOT want to let anything move, so you don't want even a whisper of it to lock your new screw into the tool you're putting it on.
Once the sleeve retainer is set, use a small file to shape the end of your screw to suit (I like to file a small dome shape on the end, so there's no burr to knock things out of alignment as I tighten the screw), install it, and put the tool to work.
Things I learned in researching lamp parts for this little essay: I thought it would be helpful to give people an online resource for these parts, in case their local hardware store/home center/lamp shop failed them. It turns out that, if my hardware store had been better equipped, I could have saved time and had even more choices. You can get caps that are directly threaded in various machine screw sizes, or caps and reducers in larger pipe thread sizes that would let you make larger screws such as you might need for a bench plane cap iron. You could even go a little crazy and have, for instance, a cap screw on your spokeshave that looks like a Hershey's Kiss (tm). The link below gives an idea of what's available from one company; I have not used this company and can't vouch for its quality or service...it was just one that I found on the Interweb.
Here's a picture - angle is slightly awkward, but i wanted to show the screw from the side - of one of these screws on a Stanley 53 adjustable-mouth spokeshave.
Lamp parts
Re: Making small knurled-head screws (long) *LINK*
Jerry Gibbs
Thanks. I have a missing knurled screw and I will try it. Jerry
Tom
I just make them on a metal lathe. You can make them on a wood lathe as far as turning the profile is concerned, and you can checker, or flute them with files, or other methods. But a metal lathe costs a few hundred and is infinitely useful. Even LV sells them, though theirs won't cut screws. The tech for cutting screws (obviously) precedes all these cast iron tools you are trying to fix.
I find a set of taps and dies, one of the most useful tools for occasional use, that I have, though they rarely produce actual machinery grade fits, which I like, though many woodworking tools are pretty sloppy anyway.
Steve Voigt
Bill, thanks very much for posting this!
barryvabeach
Bill, I bought a mini metal lathe primarily to make knurled pieces for my planes and other hand tools ( yeah, a pretty stupid investment, but I thought it would be neat to try out) I have made a few, but found out that the minilathe isn't great at knurling, and to knurl and thread a rod is a great waste of material, so I often use the same approach as you. Another option is that Lowes sells knurled nuts in various sizes, mostly smaller sizes, but you can always drill out and tap it for a larger size screw. One small tip is that if you have a choice 6/32 is not a great size for tapping - it is one of the most frequently snapped taps according to what I have read, and so if you can, try to go to 8/32, you have much more meat in the body of the screw, and the tap.
6-32 is a pretty minimal size for clamping pressure, too. I've used it only where the tool in question used that size and lacked the meat around the hole for a larger size.
