New WoodChat!
ADVERTISE HERE - FREE TRIAL
rasp handle removal?
Geoff in Madison
I have an Auriou rasp purchased through LV that I want to remove the handle from and install a LN handle in its' place. After handling the rasp with the LN handle at a show, I decided that it was indeed that much more comfortable in my hand that making the switch was worthwhile.
Is there any way to remove the handle without destroying it? I know I can cut it off, but could reuse it on another file or rasp.
Thanks,
Geoff
Re: rasp handle removal?
I suggest you contact Lee Valley to be sure. Most rasp handles are just driven on to a tapered tang, and can be driven off by holding the rasp in your gloved hand and tapping on the ferrule of the handle with a suitable light hammer. Some handles are threaded, and cut threads into the tang; these are removed by unscrewing. But I don't know how Auriou fastens them. They may even epoxy them, in which case, well...ask Lee Valley.
John in NM
The Auriou I got from LN several years ago is just pressed into the LN handle. Keeps falling out in fact, but I credit the dry air for that :D
William Duffield
I've been told that hair spray on the tang will fix that problem.
Usually, I just use a Warrington pattern hammer on the ferrule to remove rasp handles, but it doesn't work on my Aurious. I just tried it. I see a bit of glue at the joint on one of them. That might explain why I've never replaced the handles on them. I prefer a handle that's a bit longer and larger diameter.
Re: rasp handle removal? *LINK*
Bob Entwisle in NJ
Try an email to Auriou Toolworks and ask them how to remove it.
enquires@forge-de-saint-juery.com
An excerpt from the linked page: "Once we fit our French walnut handles they are very difficult to remove. If you do not want your rasp handled then please advise by covering e-mail."
Bob in NJ
http://www.forge-de-saint-juery.com/rasp-care/
Thanks for the suggestions
Geoff in Madison
I will check with Lee Valley and Auriou. I tried unscrewing the rasp, but no movement at all.
Now that I've looked more closely at the handle, I think I can see epoxy at the bottom of the hole. I hadn't considered that before.
Tom
The typical way is you slap the handle against some block. You wack it so the side of the handle hits something like the end of your bench or a block of wood. You aren't trying to split wood here, you want to whack it, from side to side, but not cause the hard temper of the flile to snap off and put your eye out. If the rasp has the typical shape where one dimension is a lot wider that the other, hit in line with the wider one, because it is stronger and has more taper.
This approach works with really tight handles like those on Japanese chisels, and molded on plastic ones.
Re: Thanks for the suggestions
William Duffield
That's what it looked like to me, but I didn't want to guess without experimenting first. If it is epoxy, most epoxies will release at around 200° Fahrenheit. You can apply heat to the tang right where it enters the ferrule, but must be careful not to overheat the toothed part of the rasp. I usually do this by clamping the rasp in a machinist's vise with soft jaws or using a soft metal interface so I don't dull the teeth. The vise works as a heat sink. I've even used soaking wet paper toweling to conduct heat from the rasp to the vise jaws.
