HandTool : Hand Controlled Tool?
charlie belden
I hold a tool in my hand,
I control where and how it works
I provide the power to make it do something,
and
I do something with it - like remove wood from a selected location
then
I'm handtooling.
VS
an electric motor provides the power to make it do something,
and
then
I'm NOT handtooling?
I have a manzanita burl - that's all gnarly and lumpy and weathered, with splits and cracks - and small rocks inside that the roots grew around.
It looked something like this - before I pressure washed most of the dirt and gravel and "skin" of it.
I know, from past experience that inside is some beautiful wood, with reds and oranges and yellows and swirling grain, with flecks and feathery grain patterns - that no one will ever see and maybe be amazed by - UNLESS - I do something to reveal all that hidden beauty.
I COULD use a brace and auger bit to hog out some of the wood that needs to be removed. And I COULD use carving chisels to remove more of the wood that I want to remove - but I'd need to sharpen my chisel every few minutes since sharp edged tools are easily damaged by contact with ROCKS - that can't be seen or felt - until the carving chisel contacts them. I COULD use scorpers to create concave surfaces. And I COULD make custom scrapers to follow the contours of the concave surfaces I'm after to smooth those surfaces - but again there are small rocks to contend with - that dull cutting edges and scrapers very quickly - or worse yet, notch the scraper. But I COULD keep sharpening bits and carving tools and keep restoring the bur on a scraper - all by hand.
The reality, at least for me, is that I WOULD NOT go through all that - to get the piece to look like I want it to look.
BUT - IF - there's a much less time consuming means of getting where I want to go . . .
In this example, an eletric chainsaw, that I hold in my hands and cause it to remove wood from where I want it to remove wood - allows me to hog out wood much faster than going the brace and bit route and then carving chisels and mallet to get to my desiired rough outcome. And for refining the inside form I'm after, I can use a hand held angle grinder with a rounded sides medium grit KutzAll disk - that I guide to where I want to remove wood. I can switch out the KutzAll disk for a series of sanding disks to refine the surfaces even more, again, with me controlling where the tool is applied. When I'm really close to where I want to go, I can switch to fine wood rasps and rat tail files and finish the almost final surfaces with sand paper - by hand. THAT I'm willing to do in order to reveal to others the beauty inside of THIS manzanita burl. Still have another 3 or 4 hours to work to do with this one - but - it'll be worth it when I'm done - I hope ; )
Now, consider all the beauty in wood - that no one will ever see or experience - because few if any will devote the time and energy and the have skills needed to reveal that beauty - using just hand controlled, hand powered, cutting tools.
[ If you value "the workmanship of risk" - hogging out most of a deep bowl shape in a manzanita burl - with a chainsaw is pretty risky - if you don't pay close attention to the tip - and wear your chaps, ear muffs and eye protection ; ) ]
