One way to dispose of sawdust
James Pickering
James P. -- http://jp29.org/wwfoldingrules.htm - Folding Boxwood & Steel Rules
James Pickering
Re: One way to dispose of sawdust
Patrick Gibbons
Just imagine how much boxwood was sawn to generate a supply of sawdust that could be sold in 80 lb sacks. I wonder if boxwood sawdust was superior to other species for the metalwork applications mentioned?
Question concerning boxwood rules
Patrick Gibbons
I bought a French-made boxwood rule from Garrett Wade a few years back. One day I went out to the shop and the rule would no longer close completely. Should fourfold rules be protected from weather extremes? Or was mine just an inferior rule?
Re: Question concerning boxwood rules
I have limited anecdotal evidence that agrees with accumulated knowledge that "wood moves." [grin] Although boxwood is chosen and processed by rule makers for this application for its stability, it can still move. I have an old Stanley #68 boxwood 24" four fold rule that also will not close. OTOH, I have and old Stanley #94 brass bound boxwood 49" four-fold rule that, in spite of laying in the same place on someone's bench for many years, is still very straight. Neither has been in my posession since they were new, so I cannot guess what climatic conditions they were subjected to for over a century, but I can at least surmise that binding boxwood in brass helps a lot to keep it from warping. I know that one exterior face of the #94 was exposed to a lot more sun than the other outside face, and expecially to the inside faces, just due to the differences in color of the boxwood. It is similar to the difference between walnut and hard maple heartwood. The exterior face-down surfaces are intermediate in color. The steel pins are designed to keep the rule flatter, but my #94 had then removed many years ago, and it is still flat.
I'm away from home, shop and library, so I can't look up some historical information I have on the making of old rules, so the following is also anecdotal:
Yes, there is (or was) an immense amount of waste in processing boxwood into rules, especially if the rule maker cared about the stability of the rules. Boxwood trees are not straight trunked forest giants, so there is a dearth of straight, unstressed wood in each tree suitable for rules. Cheaper rules would have been made from less carefully selected and processed boxwood, which would have a greater tendency to distort.
Also, IIRC, some rules were bound in brass on all edges, some were bound only on the outside edges, and of course, some are not bound at all. The more brass surfaces, the greater the stability (and of course, the greater the cost to manufacture).
