New WoodChat!
toothed stamp / froster / matting tool
Simon St.Laurent - Dryden, NY
I'm looking for a tool that doesn't seem complicated but also doesn't seem findable.
In Carving for Kids, Robin Trudel calls it a "toothed stamp". In Chris Pye's Woodcarving Course & Reference Manual, it's "a froster or frosting tool (also called a matting tool)".
I can't seem to find these anywhere. Leather tools stores have some similar things, though usually in shapes other than the squares both Pye and Trudel demonstrate. Most of the leads I've found head into letters and ornaments, not matting or frosting.
It's clear that they aren't hard to make with a large nail and a file, but the project I'm proposing is for people who may not be set up for that yet.
Any suggestions? I'm hoping I just can't get Google to behave.
Thanks!
Re: toothed stamp / froster / matting tool
Re: toothed stamp / froster / matting tool *LINK*
John in NM
Not sure I'm getting it, but something like these? --
Those are called stippling punches and don't really work so well for their intended purpose IMHO. But they sound like your description.
http://www.brownells.com/gunsmith-tools-supplies/stock-work-finishing/stock-making-hand-tools/wood-stippling-tools/wood-stippling-punches-prod396.aspx
That looks like them - the only difference is that the stamps are frequently square. I'll take a close look and try them out!
Thanks!
Patrick Gibbons
Lee Valley and Tools for Working Wood both use to carry these. Lee Valley made their own and I believe TFWW carried stamps made by either Ashley or Ray Iles. Both seem to be no longer carrying these. One can make their own easily enough using a spike with the point cut off and the pattern incised with a file. No need to harden and temper, just use as is. So mild steel of any kind can be used. I believe carvers traditionally made their own and any repetitive pattern can be used. Stars, crosses, asterisks, dots, dashes, etc.
Patrick Gibbons
Those are similar but frosters make a pattern of squares, not checkering. I see what you mean about not working for their intended purpose. I don't see how one could lay out the checkering with the precision needed with a stamp. A slight mistake in placement and your pattern is off.
Checkering is done a bit differently...
John in NM
With a special sort of file, or more recently a flex shaft tool head that has a cutter that rotates 90 degrees to the normal rotation for a rotary tool.
These tools are sold to do a much more random texture that has more or less replaced checkering on things like target grips. I've never tried them, but the pattern doesn't look deep enough to me to get a sufficiently rough texture. I have a few tools I made by welding sharpened cut nails together and re-hardening them, they cut a much deeper pattern.
Bob Entwisle in NJ
Is this the pattern you are looking for?
Search around leather tooling suppliers etc.
http://barrykingtools.com/page5.htm
or
https://www.tandyleatherfactory.com/en-usd/home/6885-00.aspx
or
http://hackbarthtools.com/1018-steel/hackbarth-steel-leather-tool-fine-6-seed-bar-grounder-stamp.html
Bob in NJ
The Tandy one is closest. The bar grounders are cool, but they are just one line of impressions.
Thank you!
Simon
Found them online *LINK*
Patrick Gibbons
I knew someone still carried them. Look at the link below.
http://www.thebestthings.com/newtools/henry_taylor_punches.htm
Re: Found them online Carving Punches *LINK*
Bob Entwisle in NJ
Ah, now that I know what to call em Here's another source.
Bob in NJ
http://www.woodcarverssupply.com/5PC-BACKGROUND-PUNCH-SET/productinfo/434425/
Perfect!  Thank you for Carving Punches
It's amazing how many names these things seem to have. I'm very happy to see these.
Thank you!
