New WoodChat!
Old wooden spokeshave rehab?
Dave (Arlington, VA)
Hi All -
Just a question out of curiosity. I've been following (and making occasional) posts here on WoodCentral for close to a decade...I think. And I can't recall ever seeing a post with someone describing how they have rehabilitated a old wooden spokeshave. I think folks have referred to the Woodjoy or other more modern wooden spokeshaves, but I don't recall anything about the older ones.
So, I am wondering....has anyone ever rehabbed one? I am especially interested in what you might have done to the blade. I've been working on one and I'll swear that the back (bottom?) of the blade was never close to flat and I am still a fair bit from getting it there after some effort. Perhaps they were never intended to be flat. I don't know.
Can anyone shed any light on this?
Thank you.
Dave
Re: Old wooden spokeshave rehab?
Paul in NJ
Hi Dave,
When new, the old spokeshave blades came with a hollow ground into the back/bottom (opposite of the bevel). This made it easy to sharpen the back flat. The spokeshave will not work with any bevel on the back since it is such a low angle tool. I have used a grinder to restore the hollow to the blade and make it possible to sharpen.
Sometimes old spokeshaves have a hollow worn area in front of the blade. You can inlet a piece of brass, bone, or hard wood to repair this. The other problem they have is sometimes the blade is loose in its mortise. You can glue in a chip of wood to make it tighter and so that it holds adjustment.
The type that has adjusters can develop play in the mechanism. If you take it apart you can peen to remove some of the slop. I don't favor this type.
Mostly I look for a shave in good shape and pass on the ones that have a worn or badly sharpened blade. I don't think I have found a decent one at flea markets or antique stores. Where I find them is at tool auctions like PATINA, CRAFTS, etc. I don't pass up a good one at a good price.
Paul Dzioba
Jack Guzman from Maine
My experience is similar. Good ones are rare and I snap up a nice one when I can find it. Most I find have the blade sharpened away to a narrow curve that is pretty much useless.---Jack
Bob Hackett
Are you looking for info on how we may have successfully rehabbed an old tool ?
If so, what are the problems you face with the one you have?
