New WoodChat!
circular moulding
circular moulding
circular moulding
paul warnock
Need some ideas here. Just got a commission to make two matching federal style card tables. here is the issue. I work almost completely by hand. (gave up thickness planing by hand after my apprenticeship was up). Anyway. my client despises the plain edges on most federal card table tops. He want at minimum a cove. I have no router, no shaper, and no desire to buy either. How can I shape the edges on 4 semi-circular table tops that will be 32 inches in diameter? The wood will be mahogany and will be a built up lamination.
Re: circular moulding
Scratch beader?
Carving Gouges? NM
Wiley Horne--So. Calif.
Have you considered using banding? It would be period correct (though perhaps not in the exact style you're considering).
Like these (no commercial interest, just showing an example):
http://www.inlaybanding.com/products.html
Wiley
paul warnock
First thought was a scratch stock, but I'm looking at a 5/8 cove with a bead at the base. Kind of big so was worried about tracking. Banding would be period correct, but my customer insists on a formed (not square edge) I kind like the challenge, maybe carving out the majority and finishing with a wide body scratch stock (so the points of contact are 2 or maybe 3 inches apart on the "fence"). Thanks.
Warren in Lancaster, PA
I carve mouldings like this. A scratch stock works nicely for small mouldings on straight or gently curved surfaces, but large surfaces and deep mouldings are not so good. And your table top will approach end grain at the ends, which does not cut well at all with the scratch stock.
If I were making this, I would try to design it so the moulding can be shaved off at a later date, in case someone realizes it does not work well with the rest of the design.
