New WoodChat!
Frank Klausz molding
Moses Yoder
Moses Yoder
In the pictures below you see a molding. I went to a wood show in Detroit about 10 years ago and was wandering around not expecting much when I happened to see Frank Klausz at his work bench. He was at the tail end of a demonstration and after he was done everyone else left. I walked over and took one of my business cards out that was a nice white blank on the back and with the card in one hand and pen in the other I asked him if he would give me an autograph. What I found out is that when Frank does something he does it with flair. He started talking to me with an accent I could barely understand and said he would give me an autograph but it had to be done right. He picked up a piece he had dovetailed together in a demonstration and began carefully sanding it by hand and making it look just right. It probably took him 5 minutes. When he was done he signed his name in pencil and handed it to me. I thanked him for it. We talked a bit and I was admiring a molding plane on his bench when he asked me if I knew what it was. He then told me he had made it and picked it up and made this 20" long piece of molding and handed it to me. Obviously it is priceless. The first pic is as I got it, the second pic shows the 45 degree angles I put on it to use it. I plan on return mitering the ends, leaving it as long as possible, then putting a walnut or cherry shelf on top and hanging it on the wall with my Lee Valley annual plumb bobs on it. I welcome all input but the main question I have is the orientation. I assume the convex sextion goes at top and concave on the bottom? I suppose it can go either way but which would look best? Thank you for your consideration.
Re: Frank Klausz molding
Neat story!
John in NM
He's one of the few guys I would really like to meet :D
I made a shelf like you plan on (only much shorter) out of a scrap of crown molding when I worked for a shop in the 1990's. Makes a great little display shelf (gave mine to my mom). The cove goes at the bottom, as you said.
The term I've seen most often for this, for reasons I don't understand, is "bed mold[ing]." It's a very common pattern in Queen Anne and other Edwardian (aka late Victorian) houses. Out here, the concave goes at the bottom.
Tom
I think you are right because the bulge at the top seems to lead to the shelf, while the cove at the bottom seems to fair to the wall, but you might feel otherwise. Good opportunity to mock it up and let your eye be the guide. Krenov was all about that, you mock it up in stages, then look at it. He might have been a genius, or he might just have mocked it up and...
It is a lot like cooking, at which I am a nothing. But I can see a flavour in my mind. And I do taste stuff as I go along. My wife who is a marvellous cook, doesn often tastes her cooking, so on the odd occasion she makes something bad, I will dare to ask whether she tasted it, an almost always she has not. Chefs are always tasting their food, and throwing the exactly right seasoning with speed, and for the condition desired, is the hardest thing to learn, but they taste.
