We value your privacy.
I'm not sure if this is a gasket cutter used in plumbing or not - if it is, it's one of the best I've seen yet. Before tapered threaded fittings, as in galvanized (or black) plumbing, a lot of plumbing was done with flat, round flanges bolted together with a gasket* between. Indeed, large systems are still done this way. I've found several gasket cutters over the years; they usually have the same center point as yours, with two L-shaped cutters, along the lines of some Japanese mortise gauges. Yours is fancier.
*Probably, as Stephen says, leather in the early years. More recently, gaskets have been of various composites, depending on the plumbing use - water, steam, etc.
In use, one of the cutters would cut the inner diameter, and the other the outer diameter, of a donut-shaped gasket. I pointed to plumbing, but it occurs to me that there are other applications for circular gaskets - wells, leather rear axle seals and some other automotive applications, etc.
I can picture, on big jobs, the apprentice getting the dimensions for the gasket and standing there, brace in hand, cutting it out, while the journeymen prepared the joint.
