Re: roy's saw stand
Wes
Hi all -
I've actually been puzzling over that one for the past week or so - and watching the video repeatedly. The design totally hooked me and I need something better for tuning up my saws.
Here's what I've been able to work out for a parts list:
2 Jaws - part that holds the saw, length depends on largest saw -- 1-1/2 x 2 stock
6 Clamp Arms - vertical struts mortised into the jaws and bolted to the frame rail as fulcrum -- 1 x 1-3/4
1 Frame Rail - top rail of center frame with bridle joint to legs Roy demonstrated, is fulcrum point for the clamp frame -- 1 x 1-3/4
2 Frame Legs - vertical members of the center frame, holes on inside for cam shaft -- 1 x 1-3/4
1 Frame Stretcher - lower brace of center frame, M&T into legs? -- 1 x 1-3/4
1 Cam Shaft - oblong octagonal shaft with round tenons on ends, spreads the lower ends of clamp arms when rotated -- 1 x 1-3/4
4 Legs - swinging legs hinged at top of center frame on either side -- 1 x 1-3/4
2 Leg Stretchers - lower braces for the swinging legs, half lap joint to leg -- 1 x 1-3/4
4 Braces - pivot hinged sticks to limit opening of legs, attached to outside of the swinging legs and hinged in middle -- 1/4 x 3/4
1 Cam handle - to actuate cam shaft -- looks like ~1" round with smaller tenon
I'm planning to start my attempt on this one in the next week or two. Planning to use ash, since its going fairly cheap these days in some good 8/4 boards.
My plan is to mock up the different frames with some scrap sticks to nail down the lengths of pieces. I've sketched it out and I think I'm close on most of them, but a few things will just be cut to fit.
I just hope I can get mine done before Roy publishes a plan. :-) I'm going to send him pix when it's done.
Cheers!
