Yankee drill bits
Patrick Gibbons
I was given a Yankee drill some time ago and find myself using it often. I know that replacement bits are available but was wondering how one would sharpen the old ones I have? Anybody do this?
Yankee drill bits
Patrick Gibbons
Re: Yankee drill bits
John Veerkamp
Just like you would any other drill bit.
I've never measured the angles, but they seem like 135 degree or so bits. I have noticed, sort of in passing, that they seem to come with the clearance bevel flat, instead of the more sophisticated curve of twist bits intended for metal or wood.
The other part of the answer is "carefully," because the temper on these bits is relatively low; they're easy to bend. The flip side of that is that they'll keep on drilling even when slightly bent, until the stress gets to be too much. So make sure you support them well, especially if you're filing rather than grinding them.
