New WoodChat!
Stringing Federal-style legs
Wiley Horne--So. Calif.
Hi All,
Suppose you're stringing a tapered square Federal-type leg. Say it's 1-5/8" square up top at the leg post. The string is 1/32" wide, ebony string on a blonde leg. There will be a paterae inset on the leg post, with stringing around it; then below the drawer box, the stringing will continue down to a cuff maybe 5" off the floor.
Question: How much to inset the string? I am thinking the inside of the string will be inset 3/16", leaving 5/32" outside the string. Looking at old examples in books, that seems OK. Looking at some samples from Steve Latta's shop, he seems to set his string closer to the edge, like maybe leaving 1/8" outside the string. (One reason I like 5/32" is that the final leg dressing may remove some material, maybe 1/64".)
All opinions, experience, wild guesses requested and welcome!
Wiley
Re: Stringing Federal-style legs
barryvabeach
Wiley, I have done a few legs. On the last set, I left 1/8 outside the legs and am pretty happy, though it was pretty different - mahogany leg, holly stringing, and graduated bell flowers. I made a few samples first with different spacing to get a feel for what I like. On a previous set, I was closer to 3/16ths from the outer edge, the legs were shorter, and a little wider, and it is a totally different look. I am afraid you will have to make a mock up leg, and string all 4 sides till you find the spacing you want. I also found that a very tiny difference in the thickness of the stringing made a big difference in how close it looked to the edge, even though both samples were the same distance from the outer edge.
Maybe you could make up a mockup leg in white wood of some kind - pine or the like - and apply dark tape, or poster paint*, to it to simulate the wood, leaving a gap to simulate the stringing, rather than doing all the work of applying stringing on a sample leg.
*an ex-coworker of mine would by now have piped up, "Contact paper!" She then would have dissolved into giggles; it was something of an inside joke in our office. As I think about it, contact paper is not necessarily a bad idea. Apply it and use a straightedge to cut out the stringing pattern, then peel off the areas you need exposed.
Thank you, Barry and Bill!
That's very helpful. And a very interesting observation about the thickness of the string affecting the 'visual distance' from the edge. I split the difference between your recommendations, and did some stringing on a leg-shaped slice of sawn veneer--on of the original offcuts from the legs. That way, didn't have to ruin a new block of 8/4 satinwood.
For this application, I like the 5/32" outboard of the string (with a 1/32 string), and the final dressing may bring it down another 64th or so.
I'll show a picture pretty soon.
Thanks again,
Wiley
Re: Thank you, Barry and Bill!
barryvabeach
Wiley, I don't think I was clear enough about the thickness of the stringing, when I said a little wider, I should have said - a really tiny amount wider. I used a homemade thicknesser for thinning the stringing to the correct dimension, and it puts a taper on the side of the stringing so it will wedge into the v shaped cut into the field of the leg. If the cutter goes a little deeper in one area, the stringing will sit deeper in the v, and when trimmed flush to the surface, will be wider, but only on the order of say .003 to .006 ( to quote a friend , I am totally making up those numbers, but they might be right) wider than the exact same stringing which is set just a little shallower, and I was pretty surprised that such a small variation would give a different appearance. I agree you should use a cheaper wood to make the sample, but unfortunately I suggest you make a full sized sample, and even apply some finish if you want to confirm what it loos like.
