A little consumerism
Wiley Horne--So. Calif.
Hi all,
I have what I need these days. And then some. Counting my blessings.
1. But every once in a while some new bug bites. Like today, I was reading Patrick's post down below here somewhere about his ordering some combination square stuff from Harry Epstein. I decided to go look around. And found these:
http://store.harryepstein.com/cp/Sdsets/HG-8.html
Always wanted nice straight slot screwdrivers. Not the wood handles--the blades. Will report further when they arrive.
2. The other tool matter is about the LV groove cutter, here
http://www.leevalley.com/US/Wood/page.aspx?p=69874&cat=1,43314,69873
Today, I tried both the stringing cutter, and the groove maker. I'd still rather bandsaw the strings, and plane them to size--I don't see how it's practical to slice through 1/8" ebony with a knife cutter. But the groove-cutter is sensational. Tool comes with a 32 thousandths cutter (about 1/32"), and you can buy 25 thousandths and 40 thousandths. These cutters are made so that you pull in one direction to score the channel, and then pull back to scoop wood out of the scored channel. It works very easily, and the channel is clean as a whistle. I have been ripping these channels with a Preston-type stringing cutter (basically a square tooth with sharp edges), or a homemade version thereto, and that works fine. But this LV cutter is the best thing yet. And furthermore, all the cutting parts are located right together, and you can see them cut--which means you can work right to the end of the channel, and leave only a short bit of cleanup at the ends. Works well long-grain and cross-grain. This is a terrific groove cutter!
Wiley
