New WoodChat!
Starrett 14D double square--Useful?
Wiley Horne--So. Calif.
Hi All,
A question came up recently along the lines of 'has anyone ever found a use for those little bitty Starrett squares?'
Some years back, I sent to Joel for this one, a Starrett 14D, 2-1/2" double square, cause I had some newfound money burning a hole in my pocket:
http://www.toolsforworkingwood.com/store/item/ST-SDOUB.XX
Well, it's still about new. Haven't used it much. But this morning I needed it. My project is in the clamps after the next to last fit-up. I needed to make final marks on the leg posts for inlay (having finally decided whether and what to inlay). Dang--I couldn't wiggle a 4" double square into position to mark the final location of the rail on the leg post, because the clamps were in the way.
The tiny little 14D did fine, without having to unclamp/reclamp:
http://www.flickr.com/photos/78661951@N07/10057459125/lightbox/
That leg post will be flush with the rail when I clean up after the inlay. Or maybe just the slightest reveal, haven't decided yet.
Anyway, Starrett 14. Yay!
Wiley
Re: Starrett 14D double square--Useful?
Tony - Memphis
I've enjoyed mine too. Wish I had the tiny blade for it. May try and order that accessory someday. I first saw one in a class being used for dovetail marking and checking. I use the small try square a lot.
Tony
I concur that those little squares are no use whatever until they're exactly the tool you need, that not much else can replace.
I picked up, at an estate sale some years back, the Starrett 453 diemaker's square, which, in addition to its function as a square, allows for a slight angular setting (about 10 degrees) of the rule. Handy sometimes, although I'm not sure it would be worth another $70 over the just plain square if I were buying it new.
Hi Bill and all,
Wonderful find! Bevel gauge for 1:6, 1:7, and 1:8 dovetails? Wonder how die makers used them?
Wiley
Draft
Casting patterns have to be tapered slightly so they can be removed from the sand; I believe dies also need a taper (known in casting as "draft"; don't know if the same term is used in diemaking) in order not to hang up on the work. I believe the needed taper may vary based on the material being used, but know precious little about this subject.
Re: Draft
William Duffield
The taper is to get the sand mold out of the die without breaking it. Getting the casting out of the sand mold is not an issue. After you've poured the metal into the mold and let it cool, you just throw it on the floor, and the sand shatters.
For an example right in front of our noses, pick up your favorite bench plane, and set a double square (or small combo square across the sides of the plane. If you check the outside surfaces of the sides, you will find they are square, because they've been ground square. But if you check the inside surfaces you will find a significant taper.
Thanks.  I said it wrong; you were clearer
Darrell in Oakville
Darrell in Oakville
Double squares are very nice. I have 3 now. Two inherited from my FIL, and one with an ungraduated blade. There is always at least one of them on my bench.
Darrell
Very.
Hi Wiley
Interestingly, Chris Schwarz blogged about this type of square a few weeks ago: http://www.popularwoodworking.com/techniques/joinery/defective-dovetail-diagnosis
He was inspired by the 4" double square by Chris Vesper, but posted a picture of a Lufkin ..
Here is my collection of 4" squares. All get regular use.
From top clockwise ... Moore & Wright (like new, purchased at a swap meet), Preston & Sons (still accurate after all these years), Chris Vesper infill (this has a little tab to enable one-handed use. Fantastic for joinery), and Chris Vesper 70mm double square (the one that CS was raving about).
