Re: Climate differences affecting drawer fit
Bruce McCrory
I am in the Puget Sound area of WA. Even in the drought cycle of summer we are looking at 40% humidity, plus. It's always mystifying to see the gauges posting 98% and higher during sunny weather. After a week of rain, and 7-inches in three days, our humidity should be at the high end; as should be wood expansion.
I have a rock maple desk that was locked into glue and screws nearly 30 years ago, after it was dragged home in a hundred warped pieces. Dust panels and drawer floors were all glued. So movement affects everything.
The center guide rails for the drawers currently have about .065 to 3/32 slop. However, a lot of this slop can be due to the conditions present during the rebuild. For fit, I did sand and scrape these guides at the time.
The case sides are 9.5" clear--solid glued boards--and the drawer walls are approximately 9.25" wide. These are fitted drawers. The face reveals have been trimmed periodically to a snug fit at present.
The guide rails control the gross drawer movement and the lipped face edges conceal the horizontal slop to about 1/16th (minus) gap exposure. I notice that one of the dovetail joints is loose.
The wood bottom-center guides are really the best way to handle extreme movement. Sliding drawer boxes on the dust/case rails can be real sloppy. Some of the drawers are missing guides, and were no fun to deal with during the break-in, tune, period. They hold less used items.
San Francisco is most likely drier than here but I would adjust drawer design and action to accommodate looser fit.
One of the frustrating things about SF Bay area is its variability in climate, based on elevation above the bay. Hoadley, as noted by Steve, is your better bet for calculating clearances. But add a bit of looseness. AND, be sure to factor it between your two varying locales.
You may be used to snug fits in drawers and cabinet doors, but us "duck people" are adjusted to loose, and snug, conditions.
