New WoodChat!
Snipe hinges
Snipe hinges
Snipe hinges
Patrick Gibbons
Snipe hinges are expensive. Horton Brass sells 3" long pairs for over $30. They are listed as black wrought iron which I would assume in this day to mean mild, or low carbon steel. I can get 1/4" by 3" unplated cotter pins (1018, mild steel) for about $8.50 for 50. That's 12 and a half pairs. Sharpen the ends with a file, hammer the tines a little, shape the bends a little, apply gun blueing and they're set to go. I can also buy 1/4 hard 1018 wire and shape my own. This sounds too easy. Has anyone made snipe hinges or used them enough to correct my assumptions?
Re: Snipe hinges
Stephen Shepherd
Re: Snipe hinges
Stephen Shepherd
Patrick,
I have made several pair of snipe hinges, cotter pins look too manufactured for my taste but they will work. The simple wire solution is the best, just snip them off at an angle works as well as pointing them as they are clinched.
Stephen
Re: Snipe hinges
Re: Stephen, a question
Patrick Gibbons
Can you detail how you made them? I have a forge but they seem to be something I could cold-form. I agree that cotter pins look too machine made but they can be roughed up a bit. I would appreciate your insight on this.
Re: Snipe hinges
Stephen Shepherd
Stephen Shepherd
Patrick,
I have made them out of wire of various diameters, I use a pair of jeweler's wire bending plyers, one round jaw one flat jaw and a small pin vise to hold the wire. It is cotter pin shape with a well formed small eye; I cut off the ends at an angle and bend them to 90 degrees before clinching the sharp ends into the wood.
I have also had sets forged up by blacksmiths for larger projects.
Stephen
Re: Snipe hinges
Patrick Gibbons
Thanks Stephen. Your comment on cotter pins being too thick is right on. Snipe hinges are conceptually nails or staples. Excess thickness can split wood. I can see that it requires a lot more work to make them properly than I originally thought.
