Hot Hide Glue question(s)
Joe in a Cleveland suburb
Hello.
Some time ago I started using hide glue a lot. I like using it. I've been buying the stuff in the brown bottle. Until recently, I never ventured into buying the granuals and heating/melting it myself.
Problem is, I'm a sporadic woodworker. Due to life getting in the way, I do my projects in little spurts; when time allows. One of the many problems with this is when I buy a bottle of hide glue, it often passes its expiration date. I seem to remember reading here some time ago that if you put some between your finger and let it tack up, it should be sticky. If not, it's bad. At that point I toss it. Why risk it?
So, I was at WoodCraft a few weeks ago and started talking to one of the guys and bought some Behlens hide glue. I could mix what I wanted, and leave the rest (dry ganuals) in the can for a loooong time (he said).
I figured I would try it since they said they don't carry the premixed stuff anymore (I think he said that) and I couldn't find it at Lowes or Home Depot anymore.
I went to Wal-Mart and bought a small (crock-pot type) cooker thing to use as a double boiler thing. Put water in it. Put a small jar in it. Mixed half and half or so with the granuals of hide glue and water. Worked amazingly well. Melted nicely and worked well out of the jar with a small acid brush. I also bought a thermometer to watch the temp and keep it around 145 or so.
I shut the boiler thing off, left the jar of melted glue in there, shuts the lights off, and returned the following weekend to find the jar a moldy mess. There wasn't much since I was able to mix only a small amount; about what I thought I would need.
I have to admit, I reheated it. It really wasn't all that moldy and my mom used to say to just scrape the mold off the cheese and it would be fine anyway... so I thought the glue might be ok too. I did notice though, the re-heated glue seemed to congeal (if that's the right term) quickly. I ended up not using since it congealed so fast.
It makes me wonder what you guys do that use hot hide glue. Do you re-use week old melted glue? Just reheat it? Do you clean out the jar (or whatever you melt it in)? If it has a little mold on it, do you use it? Maybe I should have put it in the fridge?
I'm just curious what some of you hide glue experienced guys do.
Thanks.
[/URL]
[/URL]
