Gramercy Holdfasts...a kit?
Paul in NJ
We probably all have heard tools are kits and that they can be improved with a little tweaking. I believe this is true more or less depending on the tool. At dinner prior to our Central Jersey Woodworking Association meeting the subject of Gramercy holdfasts came up. My friend William Duffield has convinced me to post here about my modification to the holdfast.
The Gramercy holdfast is a great value and works as advertised. I believe it is a good value because it has a relatively simple manufacturing process. To his credit, Joel from Tools for Working Wood has passed these savings on to his customers. After hearing good reviews I bought a pair. My initial reaction was that they were a little clunky. They need a good solid rap to get them to grab. If you look at a traditional holdfast, they are tapered in thickness from the bend to the holding pad. I believe this allows them to flex a bit and hold a little better with not as much force needed to set them.
I decided to modify one. If I screwed up I still had the other and they were not very expensive. I took my 4-1/2" angle grinder with a 60 grit flap sanding wheel and went at it. In a short while it looked like this:
You can see where I removed material from both the top and bottom. I think I could take some more off too. There is a definite improvement, they set using less force than the stock one.
Regards,
Paul Dzioba
I'll try to be more consistent about using your method.
