New WoodChat!
On starting a rebate....
Wiley Horne--So. Calif.
Yesterday, I needed to run a shallow rebate. It would end up in a hidden location, just part of a fitting process.
I didn't want to do a fence set-up, or go get my filletster from the other workbench, and set it up. Didn't want to break rhythm of what I was doing for this trivial operation.
I had an LN large shoulder plane near to hand. My first thought was just to fence the shoulder plane with my fingers for a couple of passes; that would make a shoulder to work off of. But then I thought of Don McConnell's wonderful video's on molding techniques, where he demonstrates how to bootstrap yourself into a rebate by cutting gauge, then snipe's bill plane, then rebate plane.
My cutting gauge was near to hand, so I made a pretty deep cut with it. No snipes bill on hand, so I just tilted the shoulder plane on edge at maybe 45 degrees, and ran it tentatively down the gauge line. The shoulder plane stuck itself right into that gauge line, and curled up a neat shaving on the waste side! Well, I made another pass, then another, gradually lowering the angle until the shoulder plane had worked a nice square rebate. Then made it plumb by turning the plane on its side and cleaning up the vertical edge.
Result: You can bootstrap a rebate from a cutting gauge and sharp sided rebate plane or shoulder plane. This has got to be an old technique. It would be a perfectly obvious thing to do, for someone working with hand tools all the time, and it is really, really fast, since there is no setup beyond the cutting gauge. Anyway, I wanted to bring it to the group's attention as a low-tech or no-tech way to do a basic operation quickly and surely.
Wiley
Re: On starting a rebate....
Hank Knight
Wiley, you are having way too much fun with this project! Great post. Thanks.
Hank
Lloyd Robins
It sound like that might also be an idea where a rabbet block plane could be used.
Oh, and thank you.
Hi Lloyd,
i would certainly think so. if it's fitted with a nicker, it might be possible to register the nicker in the gauge line with only a very slight tilt, or maybe no tilt at all. If I had one, I'd try it.
The key to the whole thing is the cutting gauge. I like cutting gauges a lot.
Wiley
Hi Hank,
Someday I'll start in on my screw-ups. Plenty of them, and they're fun to read about of course :) .
Wiley
I've done similar things, but with somewhat less success than you had. I think a marking gauge (what I used) may not provide as strong a starting groove as a cutting gauge would; but that's speculative.
Also, of course, the corner of the plane used to cut the rabbet needs to be precise and sharp.
ebushee
Hi Wiley,
This is the method that Matt Bickford uses as well. He documents it in his book and in the video in the link below. He does acknowledge that with a wooden plane you might tend to create a lot of wear on the arris that continually leans into that gauge mark. Boxing that corner will help.
http://musingsfrombigpink.blogspot.com/2010/12/rabbet-plane_09.html
Hi Eric and all,
Thanks! And a good demonstration by Matt Bickford. That's about all there is to it, and he shows it to be a fast, useful technique. Regarding the wear on the arris of a wooden plane, I can see where that would happen, if unboxed, and now it makes me wonder whether that's why the Thos. Sheraton method that Don McConnell uncovered used a snipes bill plane between the gauge and the rebate plane.
Matt prefers a true rebate to the more specialized shoulder plane. He makes good points about the shoulder plane being set up around fine shavings, and limited escapement so that shavings have to be pulled out. But for those of us not in a production situation, I would vote for using the rebate you have near to hand, whether it be a true rebate, a shoulder plane, a rabbet block....
Thanks for the link!
Wiley
