We value your privacy.
Been working on these prototypes of spinning wheel flyers [mandrel, whorl, and bobbin] for a couple of weeks. One is for a spinning wheel I need to restore and the other is for a friend.
A machinest friend of mine makes the steel mandrels and they have left hand threads. The whorl [double pulley on the end] has a pewter nut set in a square mortise that is threaded onto the mandrel.
They are made of hard maple, the bobbins are glued together with fish glue and mandrels are glued into the flyers with the same, after the iron is roughened, cleaned and etch with garlic. The iron wire hooks are also glued in place, the ends going into the wood are flattened to keep them from twisting.
I understand you to mean the bobbins are made of maple and I presume they are glued together because they can't be put on the spindle after the whorl is attached. Otherwise you would drill a solid bobbin out and thread on. Please correct me if I misunderstand. My question is why is a wooden bobbin necessary? Could the yarn spin on metal and skip the wood? I understand that the smoother the wood the better but I don't know why.
The bobbins are made to be removed and replaced, some wheels have 3 bobbins. They are held on by the whorl that is threaded onto the mandrel with left hand threads to prevent it from coming loose while the wheel is spinning. Then the flyer is removed, the whorl taken off, the bobbin removed or replaced and the spinning continues.
On large walking wheels the mechanism is simpler and the wool is spun onto a metal mandrel.
Patrick, the flyer assembly is pretty sophisticated. It both twists the fibers to make the yarn and winds the yarn on the bobbin. The whorl is screwed onto the mandrel so that the cord from the wheel turns the mandrel and flyer. This twists the yarn. The bobbin has a slightly smaller pulley (also with cord from wheel) so that it revolves just a little faster than the whorl/flyer. This slight difference in speed is what makes it wind on the yarn. The person spinning can change the rate of winding on by using a different one of the two pulleys on the whorl or by holding back the yarn.
Stephen, I have never glued in the hooks. I usually make a small hole and put the wire in with the flattened tip going with the grain (The tip is like a tiny spade). Then once it is in I turn it 90 degrees (now the tip is crossgrain) to lock it in place.
