cleaning square scale/rule
Jerry Gibbs
Looking for a way to clean up dirty scales/rules on combination squares etc. My goal is to make them easier to read.
Jerry Gibbs
Re: cleaning square scale/rule
Alex Y
Process I've used on el cheapos:
Solvent to get off "gunk"
Marks-a-Lot type of felt-tipped marker rubbed over whole scale to darken lines
Steel wool or fine sandpaper lightly over rule surface to get rid of any felt-tip ink and to "freshen" the surface for more contrast.
Wiley Horne--So. Calif.
Acetone will get everything but the satin chrome and etched markings. Clean as a whistle. Does not require hard scrubbing and will not scratch the finish. Safe enough for nail polish remover.
If you don't have any on hand, see if there's any nail polish remover in the house to give it a try (acetone is active ingredient).
Wiley
Edited: 2:30pm pacific
Kevin French
WD40 and a green pad?
Peter Evans
The last one I did:
1. Sandflex blocks to get rid of junk (I assume there is no rust) and eliminate scratches (Fine block) - with WD40
2. alum foil scrunched up with Autosol Shine (tube) to take off any stain, and polish
3. remove resulting deposit with paper towel thoroughly (until the paper rubs clean)
4. scrunched up foil on its own to bring up the shine
5. repeat 3.
The chemical action (little/no abrasive) of the foil also blackens the lines and numbers to some extent
