6" double square, satin
Wiley Horne--So. Calif.
Hi all,
Looking for a 6" double square that my ole eyes can read. Satin chrome blade.
Looking for first class product, but machinist grade (no bling).
Thanks in advance,
Wiley
Hi all,
Thanks in advance,
Wiley
Re: 6" double square, satin *LINK*
craigd
I have PEC (Products Engineering) with tempered satin blade that I feel is in the same class as my Starrett and Lufkin tools. Made in USA if that matters.
If you don't mind cosmetic blems, you can get them for a real bargain at Harry Epstein Co., otherwise Amazon carries them.
http://store.harryepstein.com/cp/ProductsEngineering/7105-4R.html
+1 Harry Epstein
Re: 6" double square, satin--Done deal
Thanks very much, Craig and Mr. Robins. The $15 price tag for blems at Harry Epstein was perfect, because this square is going to be subjected to some outside weather from time to time, and won't stay pristine.
Harry Epstein's must be the longest-running US tool business (83 years) that I never heard of.
For a new, unblemished double square, I likely would have bought from Lee Valley; their offering looked really good. But the $15 did it.
Again, thank you very much,
Wiley
William Duffield
Their ad doesn't say whether the blade is satin or shiny. Any more, I'm having lots of trouble getting the light just right so I can see the markings on the shiny blades, and so won't be buying any more squares that do not have a satin blade surface. I still need to buy a blade now and then, because my 4" double squares have a bad habit of going missing.
Hi Sir Wm. and all,
That's where I'm coming from too--"hey I need more light". Raking light coming in from the side. That yellow Stanley tape seems more better these days. [One day I spent a long time going through every tape at Home Despot until lucky enough to find a 1/2" 12' that happens to be on the money both inside and outside measure.]
I took Craig's word for it that the PEC squares have satin chrome finish and compare OK with Starrett. Your inquiry sent me to the PEC website and their description agrees with Craig (here's a good picture and description):
[Edited @ 2:41pm Sep. 9 to delete link. Jack Guzman had a virus alert when he clicked on it.]
I'll write when it gets here to confirm yea or nay, and how bad the blem is.
Wiley
William Duffield
That certainly looks a lot like the formerly nameless, but now "Pinacle" branded "Made in USA" square that Woodcraft sells for $41. I think you got a good deal, if the blade's graduations all align with the ends of the blade. That's basically the same issue that you (and I) have with steel tape measures. That's why I usually choose Starrett squares, because I don't have to worry about sending it back if it doesn't align precisely. On all the squares I've dealt with that are not Starretts, I've also have to spend a bit of time tuning up the blade locking mechanism to make it easy to reverse the blade and slide it back into the head.
Hmmm, never occurred to me that the gradations might not be precise at the ends of the blade. Will report back on that too, or maybe Craig can tell us....
A greater mystery (to me) is Starrett. Does Starrett have some religious objection to putting a satin chrome blade in their 6" square? They do it for their 4" of course--so what's the difference to them? Did the factory manager go nuts and make a zillion straight steel 6" blades, and they're not gonna change til they sell 'em all? Go figure. There's something obvious I'm missing...
Wiley
OT virus alert
Jack Guzman from Maine
Wiley,
When I clicked on your link my antivirus system told me that it was infected and stopped it from loading. Don't know if any of this is correct but thought I'd report it just in case.---Jack
Deleted link
Hi Jack and all,
Thanks Jack,
I deleted the link. I noticed that when I was navigating that site to find the square, a weird piece of spam came up--something to do with social dating. I'm having my iMac scanned head to toe right now, to see whether I picked up anything (that Sophos has heard of).
Wiley
craigd
I pulled out my drawer of double/combo/protractor squares (2 PEC, 2 Starrett, 2 Lufkin and a (I assume) Chinese Rockler(?). Really, I don't have a problem, I just want one (or two) of each size. Most I got well used (except the PECs and Rockler).
Far as I can tell, just holding against each other, didn't feel like getting out the mike, all of the rules are good to the ends. OK, I pulled the Mitutoyo caliper and measured in 0.25" from all 8 ends on each rule and the PECs were the best and most consistent, really close. Everybody else seems to been dropped on their heads a few times (they are old) and are a few RCHs short at one end or the other (but seem consistent on both sides of an end). I've never considered rule ends to be accurate so I hadn't considered this.
The PECs are a bit difficult to lock/loosen at first but seem to break in nicely and are now just as easy and maybe smoother then the Starretts & Lufkins. The Rockler still sucks (but is getting better). Oh, the Rockler also wasn't square but, like all these squares, is made to be easily trued.
The one thing that bugs me about these new squares is every thing is ground nice and very square, including all edges and corners. Ouch. A bit of time with a stone fixes that.
I don't what the blems are on the two PECs but they mark them as blems by grinding a short groove on the rule.
I hate to fess up to this, but...
Hi Craig and all,
"The one thing that bugs me about these new squares is every thing is ground nice and very square, including all edges and corners. Ouch. A bit of time with a stone fixes that."
You're jointing an edge. Final check for square, using your small square (with a sharp edge on it). Dang, it's perfect except just a little bitty high place right there. Short scrape with the square, pulling up a little shaving...now it's perfect
. Temptation so great, the will so weak at times....
Wiley
I like me some Starrett
Winton Applegate
Jack Lalanne once said "When it comes to food I have never told my body that I am a poor man".
I am that way about my measuring tools. They are too important to me to cut corners ( I work metal as well ). I don't look at price, I buy the tool that I want from a supplier that I like and bite the bullet.
These are all Starrett I didn't think to include the double head when I took that first photo some time ago so here is the double head. I tend to have several blades : metric, inch in hundredths and some of those weirdo fraction ones just because I don't want to seem "weird" for not having those. If you know what I mean. I am not sure I do. Anyway I am NOT weird; because I got some of those weird fraction ones.
I may be weird for other reasons not listed here though.
So
buy what you want and damn the price. Full speed ahead.
PS: I always get the satin blades when I can find them.
[URL=http://s801.photobucket.com/user/noydb1/media/PrideandJoyonceproperlydisciplined_zpsadea6976.jpg.html]
[/URL]
[URL=http://s801.photobucket.com/user/noydb1/media/IMG_2296_zps29e9c3ce.jpg.html]
[/URL]
Re: I hate to fess up to this, but...
craigd
Actually, that is neat idea, I saw that the Schwarz puts a burr on the rule for that purpose.
But I spoke too little info, I meant the edges on the stock are too sharp and needs to be dumped into a tumbler. If you are using the cast iron as a scraper, you is a better man than I!
Re: I like me some Starrett
craigd
Yumm, lovely stuff.
Have you found a use for the die makers square (bottom left)? I have one and just don't use it.
Winton Applegate
Do I use the die maker's square ?
Now why did you have to go and asked that?
We were doing so well before that.
Seriously though I liked/needed the skinny scales on a small square and bought the adjustable head (((( just in case; you know . . . cause it is cool and stuff . . . has dially knobs on it . . . adorable )))).
Some of the metal parts I deal with have two degree taper square hole/shaft interfaces and I can set the square to the one and verify the other because occasionally there are some that are not two degree but are three degree.
That's rare though. Can't get a larger angle gauge in there.
Soooooo to answer your question :
rarely and on the metal side of the shop.
L Robins
Mr. Robins is my dad.
My name is Lloyd. I hope that the square works well for you.
FOLLOW-UP Re: 6" double square, satin--Done deal
Well, it's 3 days later (2 days if you figure my order was placed after closing time in Kansas City) and the 6" double square, satin, has just arrived via first-class mail.
The square came nicely packaged and wrapped, in its own box. Box is marked 'second quality'--I can't see why. There are two little 1/4" square patches where the finish is slightly uneven on one side, that must be it. There is a 1/2" long scrape through the finish made on that side (on purpose) to mark it as a second.
The sliding action on the square is a little smoother than my Starretts. There is no light leak when I put this square up to a precision square against back-lighting.
I tested total length of the blade with a Mitutoyo caliper (which itself tests on the money against Starrett thickness gauges). It tests 5.997" and the graduations look good at the ends. Reads 1/8's, 1/16's, 1/32nds, 1/64ths. By the way, the stock on this square measures precisely 1" wide and 1/2" thick--that can be useful at times.
$15 + $4.92 shipping. I'll likely use Harry Epstein in Kansas City again. They have a 'Catalog' section of new first-quality items at wholesale prices, and then a 'Closeout' section of discontinued, blems, etc. This item came from 'closeouts':
Very pleased, and thank to Craig and Lloyd for their recommendations!
Wiley
Re: FOLLOW-UP Re: 6" double square, satin--Done de
Chuck Bjorgen
Just ordered one of the squares, Wiley. Thanks for the review and others who pointed us to this bargain.
William Duffield
Wiley, thanks for the heads-up. I just ordered both a 6" double square, to fill out my arsenal, and a 4" double square, as a back-up to the Starrett. If it is as accurate as it should be, it may end up my favorite, as the graduations on these rules will be a lot easier to see than the Starretts. I already have 12", 6" and 4" combo squares, with center finder heads, and a protractor head and a 24" blade for the 12", so a 6" double square was all that was missing. The 1" X 1/2" cross section of the head, unless grossly inaccurate, will be an added bonus. I'll check it against my setup blocks when it arrives.
For others who may be interested, Harry Epstein also offers closeout blems on other Products Engineering squares, rules and gauges at reasonable prices.
Like clamps, cutting gauges, dividers and calipers, I find I can never have too many adjustable squares, as I often have them set up as depth gauges when building stuff with multiple board thicknesses.
I don't know the details of the Products Engineering squares, but you may find it important to know that Starrett makes blades and heads in three different sizes, and their 4" heads, 6" heads, and 12" heads are not interchangeable. I believe the Starrett 6" double square and head fit the 12" tools, but are a different size than the 6" combo square. When I say "size" here, I'm not referring to the length of the blade, but to the width and thickness of the blades.
Re: I like me some Starrett *LINK*
William Duffield
I think the Schwarz may have just provided one answer to your question.
Defective Dovetail Diagnosis
craigd
Actually, that sorta prompted it, to see if there were other ways to use a die makers square other than as a square with a skinny blade. If the angle adjustment isn't being used, making a narrow blade to fit an exist double square would/might work better (my Lufkin is a bit under square and is meant to be squared with the adjusting push rod and a bit finicky to square and keep square).
The Schwarz is with you
Winton Applegate
"The Schwarz",
"feel it up"
"Sesitive fingers " no less.
I have been thrown out of forums for talking like that.
Looks like I got to you guys just in time.
Seriously the little DMS is handy but not the must have that the "impossible to get a finger or a square into the joint to . . . "
(I can't type that last bit again (vulgar and . . . oooooh I think I am swooooooning)) . . .
. . . might suggest. Even on very small joints one can use a regular small square, adjustable or fixed blade. See photos. In any case need some good light and magnification in there.
Can even just use the skinny chisel and or the saw blade the joint was made with and tell much from eying for flat and square using those.
[URL=http://s801.photobucket.com/user/noydb1/media/IMG_2299_zps8d99c659.jpg.html]
[/URL]
[URL=http://s801.photobucket.com/user/noydb1/media/IMG_2298_zps7bc0bd49.jpg.html]
[/URL]
