New WoodChat!
Chinese St. Roy? *LINK*
Chris Scholz
Chris Scholz
Just run into a bunch of videos by a fellow in China who reminds me a lot of our own St. Roy.
The little I understand is that he is traditionally educated in woodworking, started his apprenticeship when he was 16 with a traditional master, prefers handtools (he has a few power tools but they are too noisy, too much dust).
Search for 辛全生 or follow the link to youtube below, grab some popcorn and enjoy.
Chris
http://youtu.be/IYoV-8iDW_w
Re: Chinese St. Roy? *LINK*
wilbur
Thanks for posting this! I had run across this several months ago on a Chinese woodworking forum but forgot to bookmark it, and couldn't find it again. I've been going nuts trying to retrace my footsteps.
Wiley Horne--So. Calif.
My favorite part (in the first segment) is at the end where he buries the nuts for the moving filletster fence in the body of the plane, and lines them up with the bolts.
Wiley
Paul Kramer
Not as good as St. Roy?
Paul Kramer
There are no bandages or open wounds
Chris Scholz
Sharpening *LINK*
Chris Scholz
Plane blades, chisel, gauge, card scraper.
If I understand it right then flat is important but not too important, the big curved "stone" is some type of brick or ceramic stone that a friend gave him. You can go from rusty to sharp in 2 min. No idea what grid this is. Slip tones to sharpen gauges?
Angle jigs, blade holders? Not really necessary. Power grinder, Tormek? Why bother.
Last thing he says in bye-bye.
I need more popcorn, ok, going native, snails and 白酒.
http://youtu.be/hjj7R-TVvNw
Chris Scholz
Not PBS quality...
Chris Scholz
His wife's doing the video, so it's not at the same level.
Re: Sharpening
Hi Chris
Many thanks for the links. I am thoroughly enjoying them. But " You can go from rusty to sharp in 2 min." ...? Are we watching the same video? He took 19 minutes to flatten and hone an already pretty flat and hollow-ground blade. He spent forever on the higher grits.
Chris Scholz
I guess he's exaggerating a bit.
Chris Scholz
Planing an M&T the Chinese way
Chris Scholz
Part 1 sawing with bow saw, note that Chinese bow saws don't need turned handles like the Europeans do.
http://youtu.be/DN6QmocLD1A
Part 2 marking mortise and tenon with ampretty awesome marking gauge.
http://youtu.be/IcwmyVc_MAc
Part 3 cutting the mortise and tenons and finishing up. How does he make the chips jump out of the mortises like that? Check out the bench hook at 8:15
http://youtu.be/MQTqxqg8MPQ
How does he get the chips to jump out like that ?
Winton Applegate
He explained all that. Weren't you listening to what he said ?
:D
Seriously though I think it is because he is mortising on top of that thin little saw bench. Every time he hits with the hammer the springy saw bench top hits back.
Thank you for posting these. I enjoyed seeing his shop and how he works.
Nice low work bench.
Walls and ceiling painted white to reflect light.
Very practical use of the folding rule using the wood block as a fence.
I like it !
and . . . he can talk and saw square at the same time. I can't.
Well I guess that about ends the square dog verses round "dog" argument.
All that is for pooh sees.
REAL woodworkers just take a chisel and pound it into the top of the bench where ever they need a dog.
Problem solved.
Could it be that the Chinese woodworking forums are where it is really happening these days ?
I can barely communicate in English. It may be hopeless for me to try to learn Chinese . . .
. . . . now . . . I . . . am . . . d e e e e p r e s s e d.
