New WoodChat!
Help with Plane ID
Help with Plane ID
Help with Plane ID
So I decided to trade a tool with a friend for this infill smoother. Maybe I ended up with a handfull of "magic beans"?
So it's an infill smoother...nice and heavy. The blade and chipper are marked Marples. It's been a user but very solid, flat sole and good edge. No other markings to find.
I'd like to know more about it if anyone here might know. Also, I think the trade was fair, regardless. But wondering the value?
Thanks!
Re: Help with Plane ID
Brian from Monument
Are there any marking on the "lever cap" ie that brass piece with the screw?
I have several of this era plane and some have really small makers marks.
One is 1/16 inch high letters.
I May Have My Answer
Peter McBride was kind enough to contact me. He has a Slater that is virtually identical. Mine does not bear the Slater make on the lever cap so it might just be unmarked. There are 5 tiny punch marks and a hand scribed number 5 on the back of the cap but look like production marks to me.
I lapped it this morning and it performed very well. Looks like it will be a user for me.
T.
Brian from Monument
I have a book that has a drawing of the same plane.
Book is "Scottish and English Metal Planes manufactured by Stewart Spiers and T. Norris & Son"
Edite by Ken Roberts.
It is in a section labeled Marples.
Alex Mathieson also made planes of this general form.
The Spiers and Norris books show a slightly different mounting of the "lever cap".
Robin Corell in Atascadero,CA
I think you got ripped off, where's the motor?
Rubin
Really really good score!
Wiley Horne--So. Calif.
Thomas,
Home run! It's as clean as a whistle, looks to be all original wood. The Marples iron has a lot of charisma. And unhandled infills are wonderfully useful and flexible. Puts your hands right on top of the cut.
What is the blade width? What is the bedding angle? You can shim the mouth to the thousandth, unless it's just right as is.
We need to know this stuff!
Wiley
I cut it off....
It did have a power cord. I plugged it in and it did nothing but sit there. I was in no mood for investing in repairs so I just cut the damn cord off. I plan to just use it manually. Probably good exercise anyway.
T.
Re: I cut it off....
I had to do the same thing to an old belt sander.
Nice plane by the way.
Tobin
Re: Really really good score!
Thanks Wiley.
I had an old surplus bag style dust collector I traded for it.
The blade is 2 1/4" wide. Set at 45 degrees...don't know the bevel off hand. Anyway, after a bit of honing, it worked rather nicely.
T.
