New WoodChat!
Have a question? Ask Woody!
Stamps for marking wood
Some months ago I received a stamp from Mazzaglia Tools. It was a "Maker's Stamp", as they called it. Its intended use was to mark the furniture and tools I build.
The letter are 1/16" high and the stamp is 1" long. Clearly it works well, as may be seen in the sample they sent.
These stamps are intended for end grain, not face grain. Their surface area would create difficulties for the latter.
The trouble was, I struggled to impress the mark into even soft Radiata Pine. The mark on the left was attempted in a vise. The mark on the right was with the board edge-on the bench top.
I used a 375 gm hammer, which is too light according to the company. They recommend a 3 lb sledge hammer. I am too cautious to use such force, since the pieces I wish to mark include small tools thin (= delicate) furniture parts.
The situation became even more bleak when I tried to impress the mark on hardwood, such as Jarrah:
End grain ...
Face grain does not show up at all ...
Now I am not criticising Mazzaglia Tools. The stamp works, and I have seen many others apply similar stamps quite successfully. I just do not have the technique to use it, and am too chicken to develop it. I wanted to report on this feature for others contemplating a similar design.
There is an alternative. I have just received a stamp from Buckeye Engraving. This is also 1" long but about 1/4" high. There are two differences - the first is that the letters are in script, actually a copy of my handwriting. The second is that it is an "Owner's Stamp", that is, it impresses the letters into the wood, rather than leaving them raised.
It marks face grain as easily as end grain ..
These impressions were made with the 375 gm gennou.
Finally a stamp I can use without fear.
Re: Stamps for marking wood
John Aniano in Central NJ
Hello Derek,
Glad the stamps work, sort of... Here's a tip for usage: Light a candle, and pass the business end of the stamp through the flame and get the end sooty. When you then brand the wood, especially with the raised letter stamp, the soot will darken the resulting imprint. If you can affix a wooden handle to the brand using a ~1/4" x ~3" long steel rod (my brand has a threaded hole opposite the imprint side) you can then heat the brand using a propane torch to better burn in the imprint. Heat to just the scorching point and test a few times on a sample piece. I usually do the heating method + the candle soot. This marks very hard woods on face grain with ease.
Over and out,
John
Thanks for the suggestions John.
I really wanted to avoid heat. My aim has always been to find a way of marking my work in an unobtrusive manner. No glitz or fanfare, just a mark that could be found if one was looking. That is why the first (Makers Stamp) was just my name without any serrations around the edge, as some stamps have. I like the Users Stamp because it is small and leaves a neat impression without changing the surroundings. I cannot but imagine that branding would stand out like a sore thumb.
I do not own a 3 lb sledge hammer to use on the Makers Stamp. But that is not the point. I imagine that it will work with practice, although I still shudder at the result it will have on furniture. :(
The scripted version ("incuse", as I have recently been informed) requires far less force, is an alternative style, and may be used just as easily on face grain. I was not aware beforehand of the limitation of the "intaglio" (the raised lettering) type of stamp for face grain. I just wanted to make others aware of this if their intent was the same as mine.
