New WoodChat!
OT - question for fisherfolk
I don't even remember at which garage sale I picked up a couple of spools for Penn reels, in boxes. One of them is loaded with monfilament line, so I can't read the stock number. Does the line add to the street value of the spool, or would someone buying it discard the line? Put another way, should I remove it so I can describe the spool accurately in putting it up on That Auction Site?
Re: OT - question for fisherfolk
Bruce, a MN Galoot
For what it's worth, Bill, my fishing buddies change their line at least once a year.
That helps, thanks
Sounds like the line should become part of my collection of "might be useful" items, if I can figure out how to unwind it from the reel and onto something else efficiently.
I suppose it would be rude to ask how often they change their socks.
Patrick Gibbons
Fishing line wears out quickly. I'll pull off the front stuff to get to fresh line that hasn't been distressed. If not enough on the spool, I'll reload. Not changing line runs the risk of losing a big one. I'm not sure, but I don't think old line is "collectible". You should be fine losing the old stuff.
Re: That helps, thanks
Patrick Gibbons
An old tin can or anything round will work for unwinding. If you have a bow saw or want to make one, fishing line is a good thing to use to tension the saw blade.
William Duffield
…but not monofllament. It's a lot trickier to tie a knot in it that won't slip out. A simple fisherman's knot is sufficient for corded or woven line, but you need a pair of barrel knots for the monofilament. Sure, you can learn to do it, but it's not as widely known a technique to non-fishermen.
Knots
I think I can recollect the knot that served me well during my short, wildly unsuccessful fishing career.
Monofilament line, it turns out, is cheap enough that it will be simpler just to sacrifice this line, and move on to selling the spool.
So many projects, so little time.
Curt Putnam
Strip the line - especially if it is saltwater gear. Fishing trips in the salt are expensive enough that I put new line on for each offshore trip, not so much for inshore. Mono stretches when it has weight along its length. That stretch all too quickly becomes permanent. On the long range trips, guys will change line that has had a fish on over the night. Why take a chance on the line when you've spent $2K+ to be there? Mono also degrades in sunlight and with sheer age.
