New WoodChat!
Brade & Co chisel
Brade & Co chisel
Brade & Co chisel
Edward in Vancouver
Picked up a chisel at the flea market, a 13/4" "Brade & Co" chisel,"cast steel" about 8" long and about 1/4" thick at the tang, beveled sides.
I'm guessing this was intended for paring and slicing, currently it has a slight crown, and minimal pitting on the back. The handle is toast, but the chisel shows not signs of harsh abuse.
Problem is, I have a "hump" or belly about 2 1/4" in from the edge, on the back.
Was this intended?
Does it serve a purpose?
Should I remove it?
regards
Edward in Vancouver
Re: Brade & Co chisel
Wiley Horne--So. Calif.
Hi Edward and all,
I think you'll find that is Brades & Co. (with an 's'), in case you want to search company history.
If the chisel were mine, I think (without looking at it) that I would leave the knuckle on the back for the moment, until a use for it emerges. Hell of a lot of work to lap it out in one go. Right now, with the knuckle, and once you put a handle on it, you can pare in the middle of a board with hand clearance. Next best thing to a cranked chisel.
Just a thought...
Wiley
Slicks - which are at least that wide - often have a "rocker" on the back of the blade to allow steering. Slicks were, as I understand it, usually socketed. Perhaps some boat builder was adapting a large paring chisel to boat building.
I'm with Wiley: experiment with it and find out how it works before spending a long time de-bumping it.
Edward in Vancouver
Thanks for the advice.
First off though, I've got to make a handle for it.
But I won't "de-bump" it untill I've used it for a good while......
Edward in Vancouver
Spent some time with the stones, still haven't got it in any way sharp yet.
However, it is my humble uneducated opinion that the "hump" on the back at about 2 1/2" away from the edge (+/- the width of a stone?) was put there unintentionally, probably a result of countless hours of a quick polish to the back after putting on a fresh edge.....
