William and Mary Bible box, as a proof of concept
wilbur
Finally finished a project.
This is a William and Mary style Bible box, made from walnut, with a walnut burl veneer and walnut edge banding on the front. The sides are dovetailed together, I used snipe hinges for the lid and there's a lockset that's mortised in. The proof of concept is that this project, except for the turned feet, was done completely with Japanese tools.
I've often said that Japanese tools have much more in common with western tools than differences. This project, I think, illustrates this nicely. The only problems I had with this project in figuring out methods of work using Japanese tools was how to make the decorative elements: the profile of the molding, and the turned feet.
The original plan for this Bible box called for an ogee profile on the lid and the applied molding at the bottom. The reason this was a problem is that western decorative elements are the only things that Japanese tools are not good at replicating, mainly because Japanese woodworkers didn't have the need to make those elements, so those tools were never developed. I substituted a different profile: quarter round beads on the top and bottom of the lid and the molding. There's a Japanese plane that makes this decoration, and I used it on both sides of the lid and molding to make the profile.
As far as the feet go, there is a Japanese style of woodturning, with the tool selection tending towards hook tools, with the tool being positioned below center. Here's an example: http://youtu.be/Cc4mD8t-xOs I don't have these tools, and I'm not sure where you could get them. The lathe setup is a bit different from typical lathes that you can get in this country. Also (or conveniently), my fascination with Japanese tools doesn't extend to woodturning. In any case, this is again mainly a decorative issue, since I could have made a foot of a different design using Japanese tools.
And I'd like to point out that, yes, this project was made with hardwood.
