New WoodChat!
Duh!....note for LV twin-screw vise owners
Wiley Horne--So. Calif.
This is regarding planing tapered legs using an LV twin-screw vise. Or most other tapered things.
Now the vise can be skewed about 3/16", using the built in release mechanism, which unchains the two screws.
But 3/16" ain't enough to accommodate the taper on a leg tapering from 1-5/8" down to 7/8" or so.
So I was thinking, 'how did I shim these legs last time I did this'? Cause I'm all eat up with the CRS, and have forgotten.
Then it occurred to me....Duh, you don't have to shim anything. Put the upper leg post in the vise in the ordinary way, because it's square and parallel, and get a grip on it. So now you have a grip on one end of the leg, but the sawn taper is suspended in mid-air at the far end. But, forget trying to shim. Pick up a scrap piece of 2X (of the right height) and lay it loose on top of the steel stand-off stud above the far screw, so that the piece of 2X supports the far end of the tapered leg. Don't worry, that loose-lay scrap will stay there as long as the leg you're planing is resting on it. You're set. Start planing.
This fix is actually stouter than shimming, even if you saved your tapered offcuts for shims (oh, yeah, that's how I did it last time, just remembered). It's better, because the support is directly under the thing you're planing, and you're not relying on a friction fit. The 2X scrap is doing the same work as a deadman in an edge-jointing setup on a traditional bench.
Why didn't I think of this before...?
Wiley
Re: Duh!....note for LV twin-screw vise owners
Epiphanies...
... are where you find them. Sounds like you found a good workaround.
You could also make jaws like Sir William's for universal taper holding.
Sir William's vise fixture
Here is Sir Wm.'s professional solution to holding tapered stuff with any parallel-jaw vise:
http://www.woodcentral.com/woodworking/forum/archives.pl?pro=search;pmd=sread;srchid=23993Xj7wJ9kqX4UAD5q1375242272;spage=10;sanc=459434;sbid=1001;md=read;id=459434#m_459434
If I get the nerve up, I'll post a picture of my (let me put this gently)--ad hoc--method.
Wiley
P.S. Elsewhere, Sir Wm. credited Steve Latta as his source.
