We value your privacy.
I "inherited" a Disston D-8 Dual-Grip handsaw (28", 5 ppi rip) which looks to be in great condition except that it is quite rusted. Seems to me that taking the handle off would be the best way to remove rust from the blade via Evapo-Rust or electrolysis. Any do's or dont's advice regarding how to proceed? Are the saw nuts likely to be seized, etc.?
Never done this before, and I could use some advice...
Don't leave the handle and blade apart for too long. What I mean is don't take it apart then get around to finishing the project at a later date. You might find that the saw screw holes no longer line up. I learned this from experience.---Jack
Pete Taran has an article on his site. I remove the handle, and use 220 or finer grit paper with mineral spirits to sand off the rust. If there is a great amount of rust, I use a razor blade as a scraper. This takes off the majority. I use a sanding block and pay attention to the etching; I don't want to remove it. Often rust is especially bad at the teeth. The sanding needed to remove the rust ruins the teeth, obliterating the set. Resharpen and set your saw after you clean it. Use a properly sized screwdriver to remove the handle or you can easily deform the nuts. While the handle is off, evaluate if it needs work. I do as little as possible but if the handle is butt ugly you can shape it to a more ergonomic feel. It's funny but the best looking saw handles tend to be the best feeling. Smooth it if it's rough and refinish as necessary. I have acquired saws I'm embarrassed for others to see. They were poorly rehabbed by previous owners. Don't polish the brass nuts. Patina is much more beautiful.
There is a guy named "Brit" on this site : http://lumberjocks.com/topics/27984 Ask your question on this blog and you'll get some great responses.
Who has videos and instruction on every aspect of restoring saws like yours. I, too, found a D-8 w/thumbhole and restored it. They are wonderful rippers to work with.
If you could post a picture or two it would be quite useful in determining where the starting point is with your saw. What you do to it depends on it's present condition. As one who has reconditioned hundreds of handsaws, I do not recommend using Evapo-Rust or any other rust removing agents. Scraping and sanding is the way to go. In most all cases, removing the handle is preferred. Removing a D-8, cover-top handle should be done with care so as to not chip out the top front where the wood is very thin. After you remove the screws, rotate the handle upward and counter clockwise. Most of the screws used on those saws have thin screw driver slots. You'll need to grind a wide blade screw driver so it is thinner and will fit down into the thin slot. Sometimes the screw heads will be sunk down into the wood and the wood has expanded over the edge of the screw. When you remove the screws, they can split out the wood and chip around the screw head. If it appears that this is a possibility, soften the wood around the screw heads with mineral spirits and with a sharp edge tool like an Exacto knife, lightly run the knife blade around the screw heads before loosening the nuts and pushing the screws out. Most of the time the screws will be too tight to push out easily. Use a 1/4" screw or bolt and tap them out with a mallet. When you remove each screw, make sure to keep the screw and nuts matched up together and to make note as to which hole each screw was in. It's even useful to mark each screw head so you can put them back in the hole in the same orientation. I put a black dot at the top edge of each screw using a felt pen. After removing the screws, I then mark on the underside of the screw heads. When cleaning or shining the screw heads you'll remove the first dot. Polishing the screws is a matter of preference. Some people like shiny screws while others prefer the aged look.
To explain how to remove rust from a saw blade entails a long story. A close up picture of your blade would greatly reduce the length of the story. Rust will vary drastically from saw to saw. Most saw blades can be reconditioned, even ones with the worst kind of rust. But some will include pitting that renders the blade useless. A certain amount of pitting can be tolerated, but the determination is done on an individual basis.
After you have the rust removed and the handle as you want it to be, the next stage is to sharpen the teeth. The simple way is to pay a professional saw filer to do it for you. The not as easy way to end up with a saw that cuts properly is to learn how to sharpen it yourself. If you presently have a lot of saws that need sharpening and will in the future, it would behoove you to delve into what sharpening handsaws is all about. The advice you will get from people who file their own saws will vary from telling you it is as simple as sharpening a chisel and even a cave man can do it, to telling you that you have to have an IQ of at least 180 or more in order to learn the skills required. The truth is somewhere in between.
Thanks for all the comments and suggestions. When I get back from holiday I will post pictures.
What I don't get though is, why not use Evaporust? Seems to me that it is a less intrusive rust removal method than sandpaper, maybe I'm missing something...
Denis, I used a rust remover on a saw many years ago and it left the metal with a strange gray color that did diminish over the years. It just looked unnatural and was not appealing at all. As I said, it did diminish but it took many years. Some years back there was a discussion on this forum on this subject and it may still be archived. I cannot remember what the chemical is that produces this coloring but it is a well known effect.
