New WoodChat!
first time saw filing......
Edward in Vancouver
Just got in my 8" stair-saw kit today (thanks Dom!) and am now wondering how to file it. It's cut at 12 tpi crosscut. I want to use it for soft woods, blind dados and through dados.
Do I set the teeth first, then file? I have an older 42X set, which I believe will accept up to 14 tpi, this model has a series of 6 lines on the side of anvil. How much set?
When filing, how much rake, how much fleam?
Thanks,
Edward in Vancouver
Re: first time saw filing......
Re: first time saw filing...... *LINK*
Bob Entwisle in NJ
Ed,
Perhaps this link will help.
I would suggest that you practice/learn sharpening on a yard sale saw to get a feel for it. It's pretty easy in my experience, even for my first time sharpening, to make significant improvements to a saws performance.
Dom can probably give you way better advice on set before sharpening or not for a new blade though.
On an old established blade that already has some set to it, I would fall into the file first, set later camp. But I've never made a saw from a new 'no set' saw plate. I can imagine that it might be easier to file if there was some set to it to guide you along.
my 2 cents, and worth even less than you paid for it.
Bob in NJ
http://www.vintagesaws.com/library/primer/sharp.html
Edward in Vancouver
Thanks for the link! I've got the Tom Law dvd, and after the 4th time watching it, am still unsure if he puts set in a newly cut saw or not. The vintage saw link tells me to put a little set in first, then file, then reset. Also from the link, I understand I will need aprox 15-20 degrees of fleam.
Believe it or not, I'm sick in bed with a nasty head & chest cold...
Kees
This is your first saw? Don't worry too much about such details, it won't be perfect the first time anyway. You wil probably go a back and forth until you are happy with the result. Best is if your last action is filing. But even if your last action is setting, the saw will still be pretty sharp.
These kinds of tips about the perfect set and the perfect tooth are more for experienced sawfilers.
HiJak - Sawset?
Tony - Memphis
Any good suggestions for a saw set for finer saws? I have one that seems to have almost none far as a I can tell. Somebody used it to saw metal I bet as the teeth were all push over. I have been messing with it. It is a mess. I have zero experience and am trying to learn though. It does cut, it just ain't pretty. I did a much better job on a larger tenon saw (D4?) I have. Anyway, still working at it.
Tony
Re: HiJak - Sawset? *LINK*
Chuck Bjorgen
Hi Tony -- Here's an option for you.
Lee Valley Saw Set
Marv
Hi Ed,
Normally, we set the teeth first then file. But with a stair saw, you might not need any set. You will be making shallow cuts. So, in your case, file it first, do a test cut to see if the saw binds in the kerf. If it does, then set your 42X at the lowest point possible. That will barely set the teeth, if at all. Not all 42X,s are the same in that regard, so I can't give you a definitive answer as to exactly where to adjust it. So, best to start at the minimum. If the saw still binds after the first attempt at setting, move the anvil down by only 1/2 line at a time until you feel that the saw is cutting well but not binding in the kerf. I do not recommend using a Somax saw set. It will over set the teeth without you realizing it.
After you have the set so the saw cuts as you want it to, lightly slide a slip stone across the sides of the teeth. Do it only once or twice, very lighty. This is called side jointing and will make all the sides of the tips of the teeth even. Do it the same amount on both sides of the teeth.
20° or 25° fleam angle will work just fine. Hopefully, Dom punched the teeth with a 15° rake angle.
Good luck,
Marv
Edward in Vancouver
Thanks! Am just finishing up on the tote/body of the saw, and will be filing the plate in the next few days. I, umm.... haven't made a saw vice yet, and figure the stair saw body can double as a filing vice nicely....
Marv
Hi Ed,
Yes, the stair saw body should work just fine to clamp the blade when filing. Good idea.
Marv
Thanks!
Tony - Memphis
One of my favorite shopping sites!
Tony
Re: Thanks!
cstanford
Be careful with the Somax sets, the ones I had set the teeth way too low. I have a 42X but actually like the Taintor No. 7 set better. The 42x is essentially infinitely adjustable but hard to return to a certain setting later.
