New WoodChat!
Veritas Twin Screw Vise Instructions
Jerry Gibbs
Important Note:
If you are the kind of person who only looks at instruction
sheets after something goes wrong, this is one product where
you should mend your ways. If you ignore these instructions,
we can almost guarantee trouble.
Please try to save all your innovative design urges until after
you have installed the vise. As a bare minimum, at least read
through the instructions before you start being creative.
The two easiest ways to screw up are:
• By drilling holes in the wrong place and at an angle.
• By using warped wood with the intention of straightening
it out with bolts, screws and brute force later.
It isn’t a lot of fun to follow instructions exactly but this is
one time when it will save you a lot of grief.
Re: Veritas Twin Screw Vise Instructions
Wiley Horne--So. Calif.
Great quote! Are you about to install one of these? I have a modification for you, if so :) .
Wiley
Tom
That is true about reading the instructions, but it was also the case for me that they seemed to make the project, which is simple, seem very complicated!
yes I am installing one
Re: yes I am installing one
I've installed three of them. And LV's cautions about straight drilling and straight lumber are of course right on. Best not to free-hand the drilling in other words. Also, the vertical taper on the front jaw face is important--I have heard of people who skipped that because it seemed like too much trouble to them. I did not use bed bolts for the rear jaw (too lazy to do all that), just long 3/8" x 5-1/2" lag screws, counterbored with washers under the bolt heads, and have not suffered so far.
The modification I spoke of can be considered right at the end. I don't like jaw sag. LV's instructions call for leaving 1/16" or so clearance between the top of the main vise screws and the bottom of the bench top. I have used zero clearance on the three I've installed. If you want to try it, when you're done with the standard install, close the vise all the way. Then insert sticks above each vise screw, where each stick is a close fit between the bottom of the benchtop and the top of the main screw threads--just tap it in, not a tight fit, but where the threads are just scraping the surface as you tap the stick into place. Put a couple screws through the inserts into the bottom of the bench top so they don't move. The screw threads bed into the inserts, and run in the same grooves all the time. The lube you put on the threads greases the skids, so to speak, and you won't notice a drag. Or at least I don't. If you try this and don't like it, just pull the inserts back out of there.
Anyway, that's the modification. A couple of other people have done this, and they might chip in with their experience, which could be different from mine. Hank Knight did a quite fancy installation along these lines IIRC.
Wiley
William Duffield
I am NOT speaking from experience, here, as my twin screw vise has been sitting on my lumber rack, waiting for me to replace my bench top, for a few years. However, analyzing the forces on the shims that Wiley recommends, and that make perfect sense from a theoretical POV, I have a recommendation. The choice of materials for these is important. You don't want to use a soft wood, or a wood that is easily splintered. The harder the better–because they will get a lot of wear–at least hard maple or beech. Tulip poplar or purpleheart would not do, and softwoods could be disastrous (or at least soon annoyingly needing replacement). I would recommend dogwood or boxwood or a dense tropical hardwood that takes a high polish (or Corian® or phenolic). Wax it.
Hank Knight
Wiley,
My modification is similar to yours and not all that fancy. I made maple shims capped with UHMWPE that extend the full length of the screws. The screws ride on the UHMWPE. No lubrication required and I can't detect any wear after over five years of use, and no sag either. Here's a pic:
[URL=http://s50.photobucket.com/user/hankknight/media/IMG_0237.jpg.html][/URL]
Hank
A photo comparison with wood shims
Hank's is a perfect install IMO. Using the UHMW. Minimum friction and yet no wear or play. As I recall, LV sells the UHMW.
I'll show you a lesser install, so you can see the difference. Sir Wm. is right about using a hard wood, if you don't do Hank's UHMW install. However, even with a soft wood, the wear is more limited than you would think. The wear is limited, because the vise screw threads will cut into a soft wood until the minor diameter of the screw is bedded against the wood. The threads always run in the same path, so the threads do not grind up the wood fibers.
So you can see what is going on, I took a photo of a zero-clearance install, done with Douglas fir shims. Here is the photo:
http://www.flickr.com/photos/78661951@N07/sets/72157634584295586
You can see the track made by the screw threads, and see how the indentation depth is limited by the minor diameter of the screw bedding against the fir. The photo shows about 9" of screw travel, meaning that the other end of the vise screw is holding a 2"x7" x 24" (length) oak/maple front jaw, plus all the LV hardware and turning handles--all hanging 9"-12" off the end of the bench. I would estimate roughly 30 lb of weight cantilevered off the end of the bench, acting with about 3:1 leverage at this extension.
Background: The vise is mounted as a full-width end vise. The benchtop is 2-1/4" finger jointed maple, placed on LV cast iron legs (one upper pad showing in photo), with a 2"x7" maple/oak skirt wrapping the vise end and one long side, and serving as a rear jaw for the vise.
The white stuff in the photo is lithium grease, and there are two dog holes showing in the skirt.
Maybe I'll face those shims with UHMW or titanium or something one day, if it gets to bothering me ;) .
Wiley
Edited once at 12:40p
installation question
Jerry Gibbs
The directions say one screw is the drive screw and the other a follower. I am right handed. The vise will be installed on the end of the bench. If I am facing the vise, I would tend to use the right handle. If I am working from the side, I would tend to use the left handle. Since the vise has two handles, does it make any difference which screw is the drive screw? Jerry
Re: installation question
Does not matter which is the drive screw. See this text in the instructions under "Installation":
"As you begin to assemble the vise, you will notice the two vise screws are not identical. In the instructions, we tell you to assemble the vise with the driving screw (the one with the spring-loaded drive pin) on the right and follower screw on the left. If you wish to reverse this, it is all right to do so. Simply interchange the left and right vise screw at step #11, putting the screw with the drive pin on the left."
Wiley
Winton Applegate
To save problems skip the twin screw all together and just use a Klausz bench.
I have never understood the obsession of the modern wood worker to have all sorts of metal rails and screws in the way and have to thread the wood in between them or off to one side and then put a spacer thing in to stop the racking and . . .
yes I have used that stuff.
That is why I only used them long enough to make the Klausz.
The best use of a Record rails in the way is to keep your bass boat from drifting while you fish. Tie a rope to it and toss it over the side.
Not that I have any strong opinions on the subject of vises.
Re: A photo comparison with wood shims
William Duffield
Thanks, Wiley. The photo and description should be helpful to myself or anyone else installing one of these. I can now see how a softwood would suffice for this application. No need to spend the extra clams on hardwood, or even more on exotic hardwood. If one underestimates how much the shims will wear, and one eventually gets a bit of racking, one can always go back, unscrew them and put spacers of cardboard or other material between the shims and the bench top.
I used Delrin spacers
Chris Friesen
I had some scrap Delrin that worked perfectly. Low friction, doesn't need lubricating.
