New WoodChat!
Shooting Forty-Fives
Bruce McCrory
It's hot. It's got to be 150-percent humidity. The sun is burning up everything. And, I am shooting 45s in the garage. That's where it's happening. :O
I am making a miter box, and the left-hand 45 just won't go! Not on my radial arm saw, anyway. So, I can cope right-hand base (running away from me). But, forget outside corner miters. :\
The kink in going to Super Box, and getting a cheap China version miter box at extortion prices is this: I am cutting on the pull. I am right handed. And I need to pull into the back board. Have you tried cutting 45's with about two inches (I am generous) to get everything square; and, then, not cut off a thumb, or pointer pinky? Have you tried cutting base molding up-side-down? Face to the wall? :(
Well, leaving the radial saw carriage at 90, I butted the box into the fence, twisted it to a wet-thumb-45 and studdered the thing to a lineup of the blade with the far box wall. Biting my tongue (cheek actually) I scoped the alignment and did the final fine tune. 0.5mm pencil marks lined up. :b
Pulled the trigger and shot the sucker! :D
An .030 kerf can dance inside a 1/8th+ kerf, but walls aren't ninety degrees either. Not in my house .... Except two. One's in the shower stall I rebuilt. And, I rebuilt a 14-foot wall in the basement, the other one. ;)
Re: Shooting Forty-Fives
For small moldings I prefer hand sawing. The piece can be shimmed in the miter box to adjust the angle to the place it goes.
Jerry Nicholson
I usually go to the indoor gun range to shoot my forty five
Jerry
