New WoodChat!
Figuring out the cap iron....
Edward in Vancouver
Picked up a Union #7 at the flea market last week, and have been scratching my head trying to figure a few things out.
The blade was marked "Stanley", cap iron and lever cap had no markings, frog appears to be original. Maybe this was the "parts plane", in any case all the parts had the same amount of grunge on them.
Problem is, I can't get the blade to protrude enough. I can get just a whisper of a shaving, but the brass depth knob is so far back, it's almost falling off.
Fiddling with the frog placement doesn't do much.
Looking and looking, and figured that--theoretically-- if I ground off 1/4" from the cap iron, I could get enough blade to protrude to use the #7 for what I intended it to do--shoot edges.
Went over to a friend's and swapped out his L.V. blade and cap iron from his Stanley #6, --same problem in my plane, can't get the blade to protrude enough.
Any advice?
Re: Figuring out the cap iron....
craigd
craigd
My guess would be a non Union chip breaker thingie. I've run into this several times with Stanley planes, I have cap irons of several different lengths and some I've had to move the breaker up over a quarter inch up the iron to get the depth adjuster to work. At which point, I dig into the pile for a different one or make one.
I'd check with Walt at BrassCity, Josh at HyperKitten or at RustHunter to see if they have the proper chip breaker.
Or somebody here will have the distance from the chip breaker to the depth adjust slot and you can compare.
Kees
Aren't you thinking the wrong way round? I would say the capiron needs to be longer, not shorter.
Anyway, if you can't find another one, I would weld the hole and drill and file a new one.
Y lever
Warren in Lancaster, PA
The Y lever, sometimes called fork or yoke, connects the adjusting knob to the cap iron. If it were on backwards (or from another plane) it would give the symptoms you describe.
It sounds like the cap iron is for a Stanley plane, but the location of the pivot point for the adjuster yoke differs from Stanley placement. You might take the plane over to your friend's house and measure that pivot point on your plane and his. If they differ, you need the hole in the chipbreaker/cap iron to be different, too. Cutting and filing a new hole to mate with the yoke might solve the problem.
If they're the same, Warren's probably got it; in fact, have a look at the yoke first. It's usually not hard to tell when they're backwards.
Re: Y lever
Edward in Vancouver
Picked up a Record cap iron, it works well.
Thanks for all of the responses
Edward
